hey man yeah saw u give me the double thumbs up at the last second, im from bensville wbu?
Hey mate, do you have the blue or red 34r?.. Would love to see a red one in person is all.
hahha yeah I was so happy to see a GTR in the area. I live up at Killcare just along the scenic road
and he's got the blue one anthony.... The red one had a black (maybe carbon fibre) bonnet and looked awesome. I've never seen it around before.
Cheers mate, would love to see it!
Saw SilverLure today on Empire Bay drive, car is sick man. Looks the goods. I was in the black 33, I've seen you filling up at the servo too
Thanks heaps man, I've put a fair bit of time into it for a gts and I'm stoked with how its looking myself :)
I've seen yours around a fair bit too, its absolutely immaculate. You live close by no doubt?
I expect to spot everyone at the pub in charlestown on the 8th
Check out the thread in the nsw event section, were having a meet and greet for the north coast guys!
You will spot me there in the 34!! :yes:
Should have the final tune this arvo!
No worries :)
Just saw the black gtt with gold "skyline" on the back, thought it may be you.
Have seen a black gt getting around, may have had gold writing.. May have been the same one...
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
