Late 2001 Mazda RX7 Bathurst R edition (only 500 built)
Imported 2003 (all paper work)
Brilliant Black
Rego till June 2009
49,000kms
5 Speed Manual
18’ RX8 wheels on it but otherwise comes with standard 16's also
Hybrid Front Mount
Custom cold air intake with Apexi dual intake pods
3' Apexi GT cat-back exhaust (full stainless)
HKS SQV Blow Off Valve
Apexi Turbo Timer
Greddy pulley kit
10,000k HIDs
Carbon fibre interior (factory standard)
Bilstein coilovers (factory standard)
Dual airbags
Alarm and spare keys
All stock parts provided
$43,000 as is
$41,000 stock
Hardly been driven, only taken out on the weekends. It has been serviced every 5000kms since I’ve owned it. No accident history and no finance is owing on the vehicle. Will consider reasonable trades with cash my way.
Contact John 0421 430 582
https://www.sau.com.au/forums/topic/240856-2002-mazda-rx7-bathurst-edition/
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
