Hey guys,
What i had to do to post this was as soon as i go to make a new post it gives me about 2 seconds to write then the post box goes blue and can not write in it.
So i had to just push a few key get some text in the box before it closed then once i put the heading in posted it and used the edit button to write this.
Sounds like a browser issue, are you using Firefox by any chance with some plugins loaded? I'm thinking something like Adblock or NoScript that might remove or disable content. Have you tried a different browser and, if so, do you have the same problem? If not, disable all your addons then re-enable them one by one until you get the problem again. If/when you find it, you can either leave it disabled, or try to work out why it's doing what it's doing, you might have a bad filter in AdBlock for example.
Also if you have access to more than one computer (one at *cough* work for example) and don't have the issue there, it's likely to be a setting somewhere on your PC rather than an issue with your account :/
I tried fire fox google chrome and explorer same deal, I can still post on NS and other forums just SAU im having trouble with. I will try stuffing round with it and get back to you
internet security software might be disabling the field for some reason though............
do you have or have you checked it.
ps. holding the alt key down when doing a screen shot will only screen shot the window that is selected :P
Hmm could be im not sure what security we use here at work. Is it possible to stuff round with the internet security in the tools drop down??
Cheers for that will use that next time
Else where its fine just here at work and other work PC's, its just here that does it all other forums are ok.
How would i go about finding any info about the problem with the connection here??
Talk to the propeller heads where you work and give em curry about it.
Its either one of the following
1. PC level... ie I.E/PC Security setting/Anti-virus setting etc etc
2. Server/Proxy level... ie Mimesweeper or other blockers/filters and so on.
Its 110% not SAU if you can post from home fine.
Sorry we cant help anymore mate!
Cheers :D
Same thing happened to me, as a temp fix.. hit the stop button as soon as the page loads and you'll be able to post but it wont allow you to upload pics.
  • 4 weeks later...
  • 2 months later...
Hi Guys,
I still carnt get this problem fixed and now i carnt even get onto SAU from my work PC. I got incontact with our IT department and they sau its an issue with one of the host i have 2 pics that they think where the problem is.
this is the web path that it takes from my work PC
This is what it should look like he thinks
He thinks is a problem with the host “atlas.cogentco.com” taking to long.
Could someone please have a look at this to see if it can be fixed.
Cheers David
170ms is just because its in the US
Thats a fairly normal ping/hop to the US
Mine looks pretty similar to be honest and i dont have a problem.
Also - remove the first two entries dude, it gives out your direct IP, not very smart/safe :D
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
    • Yes they do. For some maybe. But for those used the most by abusers, ie Skylines, the numbers are known. The stock eyebrow height for R32/3 Skylines is about 365/375mm or thereabouts. The minimum such heights are recorded in adjacent columns in the database.
    • Hmmm, interesting. Makes me wonder whether there is bias as well. It's the cheapest fuel, so it is used for all kinds of ill-maintained shitboxes which are bound to have issues regardless. Nicer cars tend to require higher octane rated fuel and can't use it anyway. FWIW, the official NSW E10 facts page is decent.
