I purchased a 1995 GTR V Spec from Streetmachines when it was active a couple of years ago, the car was then sent to Malanco’s to have a new clutch and haltec computer install. ( by Justin) No idea where he is now.
Both of these companies have now disappeared.
The car was running sweet for a year and a half then we started getting the following problem.
The problem is simple to describe. The car was driving perfectly, but suddenly (usually - but not always - when trying to take off from stop) the engine revs up but the car doesn't accelerate. On two of the three occasions, it has deteriorated so quickly that the car has simply not made it home and had to be put on a flat bed and carried home. The last time, when the clutch had just been re-installed after coming back from NPC, I had been babying the clutch, having been told to let it settle in, so this is not a case of me thrashing it.
The problem first showed itself after I had had work done on a leaking slave and master cylinder.The mechanic told me that he had adjusted a threaded screw on the end of the slave cylinder (actually ON the end of the piston if he described it right).
Yattla headworks suggested that this adjustment screw might be an after-market alteration since he was unaware of any adjustment there, but he also admitted that he owns an R32 and is not an expert on the differences between the R32 and R33.
The clutch was built by NPC (performance clutches), and is a "pull style clutch with a modified NISMO pressure plate and a 5 puck carbotic face". When the clutch was inspected for a second time by NPC, he found that there was no damage or wear that might indicate a problem, but remachined the face, tested the springs and replaced the throw-out bearing to be safe.
Some suggestions are that either the clutch has been poorly adjusted or more likely since there is no wear or damage to the clutch, that the transfer case is gone, but could not answer my question as to whether the transfer case is direct drive to the rear wheels and hydraulic clutch to the front OR hydraulic clutch to both front and rear wheels.
If the transfer case is direct drive to the rear wheels then it does not explain why the the car loses power and won't drive at all.
I have had the gearbox out 2 times so far and still don't have a solution, this is costing me a fortune, it would be worth it if it was fixed.
Can any tell me if they have come accross this problem before and how it was fixed
Cheers
https://www.sau.com.au/forums/topic/241036-please-help/
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
