Rb25det Neo!!!!!!!!!
Hi everybody in Aus.
I'm nissan cefiro a31 owner from Thailand.
Now I search some data for dicision about my new engine.
(My old is 240,000Km)
my old engine is RB20DE AT with 4.083 (Don't know its called in english..)
I interested about NEO Engine but don't know about its spec.
I would like to know about this engine detail.
I saw a few used engines in Thailand (It came from Japan) I think it's very new & Interested!!!
Could u give me some detail of this engine or some suggestion please ?
I will wait for ur answer
many Thanks :)
Tumso
https://www.sau.com.au/forums/topic/24126-rb25det-neo/
One thing I heard that NEO6 is save ur petrol right?
You know in Thailand petrol is expensive (If u compare with our living costs ):) & my city Bangkok was very traffic jam
or If I find some new engine for save petrol it's will be NA engine RB25DE NEO or not NEO :)
Anyway wait for suggestion........:)
https://www.sau.com.au/forums/topic/24126-rb25det-neo/#findComment-516474
If you are worried about spending too much on petrol, why are you ready to spend all that extra on an engine????
Sorry, just doesnt add up.
An RB25DE shoud fit no probs and with the money you save from the conversion (vs RB25 NEO) you will be able to afford the petrol.
So is the RB25NEO more economical than an RB20DE? and by how much. Really if you want economical, buy another RB20DE, they are as cheap as chips. Even an RB25DE can be picked up for around 1K in aust, but as the NEO engine is a bit rarer, I wouldnt have a clue what they are worth, but I am sure they are more expensive again.
https://www.sau.com.au/forums/topic/24126-rb25det-neo/#findComment-518504
Have a look at some of the back issues of HPI - did a build up on a R43 GT-T, and they used a high flow for approx 230kw(from memory) at the rears.
I believe the NEO has a larger range of VVT than the R33, also the cooler on a GT-T is different to the GTS-t (presumably alot better) It would be quite conceivable that with a better tune, better cooler would easily make an extra 20kw.
BUT I think tumso is looking at the DE?
Tumso, you will also have to get an ECU upgrade if you change engines.
https://www.sau.com.au/forums/topic/24126-rb25det-neo/#findComment-519033
the best thing to put in your cefiro is an rb 25 from an r33 rather than the neo as the that rb25 is similar to the rb 20 the neo is very differnt. yes I have seen cefiro's with rb 26 :D they go very good. another thing to think of is an sr 20 I put one in my r32 skyline came up well .
meggala
https://www.sau.com.au/forums/topic/24126-rb25det-neo/#findComment-519044
HI
Tomorrow I will go to see RB25DET NEO MT. It was from R34 accident car with 4000 Km It's very very new!!!!
I quite interested Turbo engine 'cause I think if I must conversion my car How can I put Turbo because it a final aim for conversion
Isn't it?
Neo is very new. sometime I afraid about some engine parts but I just know some parts it will use with rb25det normal too.
I have some interested spec for RB25DET NEO
RB 25 DET (NEO) year 2000
DOCH 24 V
(C.C.) 2498
(m.m.) 86.0x71.7
9.0 : 1
PS/rpm) 280/6400
(Kg-m/rps) 34.0/3200
4.083 (Auto 4 speed)
4.111 (Mannual 5 speed)
https://www.sau.com.au/forums/topic/24126-rb25det-neo/#findComment-519566
Yesterday I went to see a skyline r34 engine rb25det neo for conversion my car.
Unfortunatly! air flow was broken.
I saw neo engine air flow was Pink label
same RB 25det (r33) but not sure it's really same.
If it same I will purchase a engine cause I think I can find a spare part
if not I must find another engine
Pls Tell me
Thanks
https://www.sau.com.au/forums/topic/24126-rb25det-neo/#findComment-522410
  • 3 weeks later...
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
