hi all, posted this in another thread but thought i would start a new thread
heres my problem, I'm not making any difference from 14 psi and over,workshop thinks its cause of the wastegate (T04), it had 2 "bedsprings" hanging off with one attached to the turbo and one not, due to the seller of the car taking it off so i wasnt learning how to drive it with it pushing out close to 1.5bar
we thought it was a restrictive cat but later found out that it was gutted anyway :), so replaced that with a 3 inch one and still the problem remains.
have turbosmart e-boost as well.
any suggestions?
gone
https://www.sau.com.au/forums/topic/24143-internal-wastegate-problem/
I'm getting similar problems with my T04, and similar unknown causes. Part of the problem *was* the wastegate, but not all of it. I upgraded it to a stronger unit but I'm still having slight surge/hesitance problems in upper rev ranges. The next step for me is a bigger dump pipe and machining out the exhaust housing a bit, but I don't think that's all of it either.
I think most of the reason is just that this turbo doesn't like high boost.
  • 4 weeks later...
I haven't done anything with mine yet :P I'm waiting for the PowerFC to arrive, and then I'll see if I can tune the flat spots out. If so then my wastegate must be ok. But I won't know for the next week or 2 at the very least.
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
