Have you tried carsales.com.au, ebay or your local paper aswell?
Im trying to sell my R33 at the moment too, and the market is farking slooow
It is bull sh@T slow I have had the car in the trading post, Courier Mail it is in car sales, I've put flyers up every where, and now I have got it on ebay . I really don't know how to sell it if anybody has got any ideas please let me know.
I DON'T WANT TO SWAP THE CAR FOR ANOTHER CAR OR BIKE.
  • Replies 101
