hey all, just curious if i could get some rough prices on spraying a full bodykit, and for spraying a whole car (r33) im still deciding whether i should spray just the kit as im getting a new one, or spraying the whole thing.
if someone could give me some rough prices on both, or some websites for workshops in vic that i can browse that would be great
PS ive tried searching, but no luck.
peace
https://www.sau.com.au/forums/topic/242059-spraying-price/
  • Replies 58
the one at the top of this thread dosent have any websites, i dont really have time during the week to visit all the workshops :)
yes it would be definatly better if i spray the whole car at the same time, but more expencive ;) my current paint job bar a few things here and there is pretty decent. so yea
https://www.sau.com.au/forums/topic/242059-spraying-price/#findComment-4222350
i checked the sticky, only DT panels didn't have a #, everyone else did.
depending where you are, if you're on a budget, DT Panels or Primal Garage (don't have personal experience) - one is east, one is west.
seriously, search harder... panel beaters/spray jobs/body kits, etc... those threads pop up with regularity in the Vic section.
https://www.sau.com.au/forums/topic/242059-spraying-price/#findComment-4223240
... 800-1500 for a full respray + kit. I know some places thats all they charge... but you pay for good work. I'll just say that much.
Micolour will be substantially more than that, but then the work is without fault.
Also where is the kit coming from?
If its a copy kit... A lot of the time it isn't going to fit. There will be work required to make it fit correctly.
Hell even transit can warp body kits etc. So its highly likely.
Id' budget 3k at the bare minimum. If it was my car, i'd be budgeting 5k.
As ive said before... any spray can look good. Its 5-10years later that the really good work shines when the cheaper jobs fail due to poorer materials, prep and so on associated with low cost.
Oh, and most places dont have websites... its hard to quote anything online without seeing the car. Always best to take it for a visual.
Cheers
https://www.sau.com.au/forums/topic/242059-spraying-price/#findComment-4224056
ok, kool thanks guys
and whats ur oppinion on spraying the whole car as apposed to just the kit? i can fix the parts of the car that are damaged easy enough, i just dont want to do the whole car if i dont need to...
https://www.sau.com.au/forums/topic/242059-spraying-price/#findComment-4224179
From the two shops you mentioned, i would recommend DT Panels and not the other one.
Some panel shops create an orange peel effect on your panel. This shows the quality of the work. Experience from many people showed that we shouldn't be too anal about the cost, it is the effort put into the spray painting.
https://www.sau.com.au/forums/topic/242059-spraying-price/#findComment-4224721
lol yea im not going to swap my house for a paint job on my car, if, IF the paint starts to look dodgy after 5 years, ill get another paint job, it will still be under 5k or 10k$
it might look dodgy but maybe i should just get the panels that have the damage on them sprayed? im just afraid the colour will be to different, i mean, the origional paint on the car hasnt faded bugger all, so perhaps im in the good!
PS its not a show car, its my everyday car, there will be stone chips etc, so im not gonna be extremely anal about it, aslong as its a decent job with no paint variations or bodgy paint spraying...
https://www.sau.com.au/forums/topic/242059-spraying-price/#findComment-4224810
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
