Car: '97 (JZX100) Toyota Chaser Tourer V
Colour Dark Green/Black (looks black in most light)
Engine: 1JZ GTE VVTi single turbo
Gearbox: 4Sp Auto
Price: $16600
I am the first Australian owner of this car which was bought as a grade 4B (very good condition) car from the auctions in Japan. It already had a new timing belt, the 3 piece, 17" Intelesse wheels, Rs*R lowered suspension, air filter, 3" stainless exhaust, and Dvd/Vcd player, and TRD front grille fitted.
Since purchase, I have fitted smoked front indicators, a full Trust Spec-M intercooler kit, Torsen LSD, 3" downpipe, and an Apexi Power FC ECU.
The car has been modified for economy (leaving plenty of potential for further performance from the current setup, and other mods, if desired), and after fitment of the above parts, gained both power (now 265HP at the wheels), and economy (gained about 100km per tank). It has been fastidiously maintained, and perfectly reliable. One of the best presented, sensibly modied Chasers in the country: mature enthusiast owner means all work has been carried out by professionals, and no corners cut.
Any enquiries, please either call me 0413003013, or email: [email protected]
Cheers,
Micah
swap for silvia plus cash ur way
link.... click here
kyle
Thanks for the offer, but I have another car already in compliance, so am looking for an outright sale.
Good luck with the sale!
Micah
Manual conversion would be around $5500-$6k if you paid to have all work done....assuming you could find a decent R154 Gearbox. That said, a Manual in the same condition as mine should have about a $8k premium, so I guess it would be a cost-effective exercise, if you look at it that way...
The cheaper option would be to get MV automatics to shift-kit the auto, and strengthen it, then retune the transmission and engine for better performance with the Power FC, and have a rip-snorting auto for very little outlay.
I know there's no substitute for 3 pedals, but auto suits these cars, IMO....
Thanks for the comments and free bump!
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
