WTB: Stock R34 GT-T Rims
a friend of mine had an r33. when he bougt it it had r34 rims (17") and they would hit the calipers but only every now and then, when cornering hard when the rim flexes so he put 3mm spacers and that was fine then . i must say i was surpriced that they hit he has sold the car since otherwise i would measure the clearance but it was like 1 or 2 mm without the spacers .
Guest RedLineGTR
Originally posted by eriktufa
ask FLIP, he got it,
I love bayside blue :D
How much do you reckon 2002 r34 in oz?
if we are talking about really good condition ones i think it vares from model year etc..i can give u a range form 30k-45k or so. Depends on mods and other goodies.
