infulleffects Posted October 30, 2008 Share Posted October 30, 2008 Hey guys How many people on here have actually done an rb engine conversion to a dirty 30? I am going have a crack at it in a couple of weeks.... Anyway heres some pics of it as it is now. Link to comment https://www.sau.com.au/forums/topic/242534-rb-into-a-30/ Share on other sites More sharing options...
r30kansai Posted October 31, 2008 Share Posted October 31, 2008 Have done it twice now to HR30's. Link to comment https://www.sau.com.au/forums/topic/242534-rb-into-a-30/#findComment-4232715 Share on other sites More sharing options...
OUTATIME Posted November 1, 2008 Share Posted November 1, 2008 dropped an rb20 into my r30 the other week. used rb30 (r31) engine mounts and bolted right up. used the l24 gb xmember and that bolted up. just had 2 bend it slightly to line up with the studs. bit dodge but all gd. other option is 2 make a custom one. and 4 the tailshaft i used a c210 manual shaft with the l24 centre bearing housing and that all bolted up fine. now have pulled it all out again to put it into a dr30. all same but have 2 make custom gb x member cos fj mounts r way off. also used the r30 l24 engine xmember... Link to comment https://www.sau.com.au/forums/topic/242534-rb-into-a-30/#findComment-4233553 Share on other sites More sharing options...
skybt1 Posted November 2, 2008 Share Posted November 2, 2008 i modified engine mounts and made a gbox x member so everything clears to pass engineers. engine will fit with standard r31 mounts but has no clearance with the l24 engine x member. If you want to do it just to thrash around its easy, if you want to do it properly you need to make mounts. Link to comment https://www.sau.com.au/forums/topic/242534-rb-into-a-30/#findComment-4234733 Share on other sites More sharing options...
Boof Posted November 2, 2008 Share Posted November 2, 2008 Don't worry about the engine conversion what wheels are they?!?!?!?!? Link to comment https://www.sau.com.au/forums/topic/242534-rb-into-a-30/#findComment-4234929 Share on other sites More sharing options...
r30kansai Posted November 2, 2008 Share Posted November 2, 2008 What engine did you have in it? Link to comment https://www.sau.com.au/forums/topic/242534-rb-into-a-30/#findComment-4234935 Share on other sites More sharing options...
infulleffects Posted November 2, 2008 Author Share Posted November 2, 2008 Um it has currently got an l20et in it. Am wanting a bit more power that it can offer, so dropping a 25det in. The 17s are DTM frifts, 8" front 9" rear, and the other photo has the old 2 piece hartgers, 15 by 7" Yea had guesed that I will need to do a custom gbox mount, but if I can get away with the rb30 engine mounts that would be good. Was also thinking of just getting a one-piece driveshaft made up maybe, funds permitting. Link to comment https://www.sau.com.au/forums/topic/242534-rb-into-a-30/#findComment-4235274 Share on other sites More sharing options...
r30kansai Posted November 2, 2008 Share Posted November 2, 2008 Both my conversions were previously L20ET, I didn't change the mounts or crossmember or Gbox crossmember, everything bolts straight in using original mounts, just have to get the driveshaft shortened. The L20 crossmember and mounts are different to the L24. Assuming the RB25 uses the same cross and mounts everything should bolt straight up. Link to comment https://www.sau.com.au/forums/topic/242534-rb-into-a-30/#findComment-4235329 Share on other sites More sharing options...
skybt1 Posted November 2, 2008 Share Posted November 2, 2008 sounds like i had to do everything the hard way.. What crossmember would be ideal for an RB then? l20 fj20? Link to comment https://www.sau.com.au/forums/topic/242534-rb-into-a-30/#findComment-4235668 Share on other sites More sharing options...
OUTATIME Posted November 2, 2008 Share Posted November 2, 2008 (edited) i just used the l24 (manual) 1, on rb30 box. was massive budget conversion and just used what parts i had. i did elongate the engine cross member where the mounts bolt on so the sump would have clearance. Edited November 2, 2008 by OUTATIME Link to comment https://www.sau.com.au/forums/topic/242534-rb-into-a-30/#findComment-4235713 Share on other sites More sharing options...
r30kansai Posted November 2, 2008 Share Posted November 2, 2008 Does anyone know if the RB25 uses the same mounts as an RB20 for engine and gearbox, I think they do but I can't confirm it. I have heard that the FJ20 models do need a change in cross members. It was covered some time ago, a quick search should bring it up. Link to comment https://www.sau.com.au/forums/topic/242534-rb-into-a-30/#findComment-4235852 Share on other sites More sharing options...
OUTATIME Posted November 2, 2008 Share Posted November 2, 2008 the fj mounts r way off when i put the rb20 in. just used a piece of 40mm box steel and bolted it to the floor... Link to comment https://www.sau.com.au/forums/topic/242534-rb-into-a-30/#findComment-4235935 Share on other sites More sharing options...
Factory 5 Posted November 2, 2008 Share Posted November 2, 2008 i think this really needs to be made into a tutorial or sticky post as it keeps coming up with different combinations and solutions Link to comment https://www.sau.com.au/forums/topic/242534-rb-into-a-30/#findComment-4236457 Share on other sites More sharing options...
infulleffects Posted November 3, 2008 Author Share Posted November 3, 2008 yea all rb stuff is interchangable and has same mounting I believe. Am going to use an rb30 box anyway since 25t ones are massively overpriced. Well until it blows anyway. Well I may have to take some pics of the conversion then when I do it, just for future reference. How do the 30s go with the rbs? Being a lot lighter than 32s I could imagine quite well... Link to comment https://www.sau.com.au/forums/topic/242534-rb-into-a-30/#findComment-4237510 Share on other sites More sharing options...
Factory 5 Posted November 3, 2008 Share Posted November 3, 2008 Well its definitly easier to work on with an RB, plus parts are easier to come by, more aftermarket parts available, plus a few thousand more in production than the L20 so theres HEAPS of second hand shiz about. when you look at the weight of the R32, R33 and the HR31, then the weight of the R30.... the Kw per kg factor comes in and the R30 wins, as long as you have the brakes, suspension and tread to match. my mates 190kW oz R31 haf a RB30e+t, whent like the clappers, lit up in nearly every gear, looked great, BUT had stock brakes and shit lowered springs, so in a straigh tline it was insane, as soon as ya needed to slow down or take a corner, either locked up, got sideways, or brakes faded so make sure you do the WHOLE deal, not just under the bonnet! seeing as i just got offered a complete RB25de setup for $400, im considering it thats for sure... Link to comment https://www.sau.com.au/forums/topic/242534-rb-into-a-30/#findComment-4237600 Share on other sites More sharing options...
infulleffects Posted November 3, 2008 Author Share Posted November 3, 2008 well its got d2s all round atm, the 4pots and 280mm rotors up front, and wen the engine gets dropped in I will do the 2pots on the rear, so stopping and cornering should be alright. only thing that may be a little low is the tread width on the rear...only 235 atm. planning on getting adjustable castor rods, and doing all bushes too. Link to comment https://www.sau.com.au/forums/topic/242534-rb-into-a-30/#findComment-4238770 Share on other sites More sharing options...
ydr030 Posted November 10, 2008 Share Posted November 10, 2008 Does anyone know if the RB25 uses the same mounts as an RB20 for engine and gearbox, I think they do but I can't confirm it.I have heard that the FJ20 models do need a change in cross members. It was covered some time ago, a quick search should bring it up. same 4 engine, and if u go 20 box to a 25 box, same. ive said this before and dont wwant to cause another dispute. fj cross member way off. mr 30 cross member fine. o and 30s wit rbs go alot better than ne L series motor. Link to comment https://www.sau.com.au/forums/topic/242534-rb-into-a-30/#findComment-4252567 Share on other sites More sharing options...
works 510 Posted November 10, 2008 Share Posted November 10, 2008 I recently just starting doing a rb25 convo into my ceffy and have found the 25 mounts to be different to the rb20 mounts (I had to use the rb20 mounts as the 25 mounts were going to sit the motor on a funny angle) But at the same time, I pulled a rb25de out of a car the other day and the mounts looked identicle to my rb20det mounts... Link to comment https://www.sau.com.au/forums/topic/242534-rb-into-a-30/#findComment-4253138 Share on other sites More sharing options...
infulleffects Posted November 17, 2008 Author Share Posted November 17, 2008 So... does anybody have the pinouts for the l20et ecu handy that they could email to me? And maybe the 25det ones if someone here has them for some reason, but I will ask in the later model section if no-one does. The engine should be arriving later this week....yusss Cheers guys Link to comment https://www.sau.com.au/forums/topic/242534-rb-into-a-30/#findComment-4267341 Share on other sites More sharing options...
infulleffects Posted November 18, 2008 Author Share Posted November 18, 2008 PS my email is [email protected] Link to comment https://www.sau.com.au/forums/topic/242534-rb-into-a-30/#findComment-4268053 Share on other sites More sharing options...
