Sure..
Anyway guy, with workin my ass off and Holidays and the printing place being on holidays.. should be picking them up today or monday, so will organize with everyone to get them to them, again sorry for the delay with this batch, just been busy as all hell.. workin in retail at this time of the year = hell busy for me!
skyline1989, I work at Harvey norman factory outlet, south road mile end. Im there 9-5 monday-friday.. but let me know what day you will be in as my hours do change at times..
  • Replies 486
Posted Images
preis, im onto it..
Lauren/kye at this stage NONE are left and i wont be ordering more.. I wont be taking money for anymore until i get at least FIVE more confirmed orders, as this is the minimum order.
So if you order 2 i want 3 more before i will even place an order.
sorry for the delay with this batch guys, tried ringing a few times to pick up but the printing staff were all on holidays - lucky them!
Anyway, ill have them thursday, so will organize with people to get them to them.. dont think ill be at vilis or such this friday, but can work something out..
ok, im going to pick this next lot up, finally.. so have to work out how to get them to people now!
Dohmar + madaz, you can probly pop around to lukes to get them sometime over the next few days/weekend (not tonite though)
and i can maybe try to get to vilis for a bit tommorow night if people want to do that?
So I have these 10 now to hand out. Im happy for people to pop past my work tommorow between 9-5 to pick them up from me, or as I said, I can probly get to vilis at 7ish tommorow night..
so, some details for everyone!
Calendars are $24 each. For $20 I couldve got them with just 1 pic on each page, so im sure we wont all mind paying an extra $4 for 3 smaller pics the bottom of the date page.
Ive tried to keep the cost down as much as possible, but i think $24 for a calendar is pretty reasonable? I am going back to see the designer again tommorow to finalise it all and start the printing process.
few people picked their calendars today from me at work. Now, ill be at vili tonite around 7-7:30, so if people want to pop past there to pick theres up, i should be there for maybe an hour?
can thank me johnny :)
flick just rode passenger as usual lol.
I should really get around to putting this calendar up, i think it can be December the whole year :)
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
