JERRY JERRY JERRY.........
jerry not needed lol .. its unfortunate it had to escelate like this , lukily we have some people with common sense such as paul ... i dont want to make anything big out of it ... just trying to prove a point ....
  • Replies 46
Chris,
common sense , even if someone has or hasnt reported something like this , im just saying that religion shouldnt be brought in anyway ... that prodominals always had a big mouth anywa talks to much sh** unfortunately , needs a smack in the head if you ask me....
You are entitled to your general opinion and to express it in a non personal directive. By that last comment you have just undone any remote chance of credibility of your prior comments, by making a such a juvinile retort seen all too much on forums these days.
Keep you hero 'opinions' to yourself, it doesn't get you anywhere.... to quote a famous phrase "No one thinks big of you"
You could of easily conveyed your thoughts / msg by simply saying you disapprove of the thread, all in all buddy, just avoid making personal attacks as we try to keep things friendly on here and I'm sure if you actually meet Primordial, you'd know he is actually very friendly, nice, intelligent person who started this in jest. (not that i condone it)
This thread should have been deleted after about 2 posts. Jokes are only funny when they aren't offensive to other people who use the forum. and I would say, joke or not, a party to celebrate people being killed who be offensive to a whole lot of australians no matter what their background. it may go down well in the US where the death penalty is still practiced in various states, but it doesn't go down well here at all.
In future if you (and I mean anyone) see a post or thread that offends you, simply hit the 'report post' button at the bottom of the offensive post. it's not dobbing. it's helping moderators do their job. the moderator still makes the ultimate decision whether or not to close the thread, delete the single post, delete the whole thread and/or warn and ban users. Your report will just draw their attention to the fact that there is something they need to look at. Jumping in to the argument doesn't help, it just keeps it going. No body apart from the moderator concerned will know you reported a post and it's a good service for our forum. Moderators cannot be in every thread all the time. We are not omnipotent (well I am, but most aren't). Most if not all of the Admin/Mod team try to 'police' the forums in a fair and un-biased fashion but we do partly rely on users for their help in keeping the forum fun for ALL users. So if you're unhappy with the way mods are doing their job, then do something to change it, report posts that offend you, or you think breach the spirit of the forum.
