  • Replies 40
Posted Images
its actually Chris Milton of adelaide engine developments, and yes he has just meta-laxed an n1 block and heads, pistons ,rods etc? for me and assembled it to formula1 tolerances, and he has told me i can rev it to 11000rpm it is an rb26 still and produce around 1100hp. all was rather cheap as i am good friends with his son Sam.below is a photo
oh the spl t51 should be ok or i may have to look at a t88 but i dont want too much lag.,.....
i wholly recommend chris milton as an engine builder
chris and sam know their shit, they just finished my N1 motor, good for 1100kw.
thats a s#&tload of grunt! Is it for track, drag or.......... street?? :P
on a side note, i'm aiming for a reliable 600-700hp
I was planning on using the tomei sump baffle kit, wanting the best protection for the motor.
I've read on here that some members use an extended sump with baffles, should I be doing the same ? Or is this just overkill?
no definately go the baffle and also get a tomei oil restrictor fitted to the block just some extra insurance rb's dont EVER like being starved of bearing oil. they hold alot of oil in the heads when revved hard.
F1's rev to 20,000 rpm.
51's will still have plenty of lag on a 2.6.........did you consider going 2.8 or even 3.0 litre, more cubes = less lag.
what bottom end and sump setup you running that can handle 1500hp?
yes i did consider an rb30 but i want it to scream, i will most probably settle for a Garrett 3037 pro(No smaller) thats about 800hp with 80mm gates ,my r34 gtr has hks gt-rs' and that pulled 343kw on willal's dyno but i cant rev it too hard 8500rpm on standard motor with 270 cams and injectors, power fc and boost kit with z32 Afm's . with my 32gtr I want heaps of mid range all the way to 11grand, i wonder what that will feel like on mallala's twisty turn 1. in a 1200kg r32 GTR, i spose the motor might last a little while longer with less power ,but you're right the 51's will be lag monsters, its really a tough choice, any suggestions?
dry sump for sure.
Edited by ax53b70p25
dry sump for sure.
yep, check this............unless you're interested in straight out drag racing alone, this may be a better solution for the street over a 51 or especially an 88, lol
Monster Twin Setup
thanks, will call them monday.
Not sure, but some quotes i've been given were astronomical!
What price is astronomical?? Has the engine actually given up yet...
Also consider putting a sump baffle in and the oil restictor in the head like the others said.
Have they told you what brand bearings,pistons,rods they like to use in the quotes?
I would source all your own parts like dangerman 4 said..and would want to see them going in the engine.
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day
    • While I was waiting for the new parts to come in for the charge pipe and radiator I decided to do some turbo modification. The drive pressure (exhaust backpressure) was a lot higher that I thought it should be. For 32lbs of boost drive was 55lbs. The turbine housing is a 1.10AR and my turbo builder has suggested to go to a 1.25AR. To test if a larger AR would do anything to reduce drive pressure AND not spend any money I decided to hog out the divider in my current housing. I removed it from the inlet and the whole way through the housing.  After reassembly and testing it doesn't look like this modification did anything for reducing drive pressure or requiring more fuel (making more power). Oh well, it was worth a shot. We'll get some data at the track if it makes it past the 60ft. I also machined a $7 shift knob off Amazon to fit my Stillway shifter since I didn't like the Stillway shift knob. Next on the list was the radiator replacement and fabrication of a new intercooler tube that had no silicon coupler. No pictures of this - I was short on time each night after work to get this done and didn't stop to take pictures.  Next was to get the clutch disks out and replaced. Previously when installing the dogbox I had ordered a set of the same sintered iron disks I had been running because I switched to the 26-spline input shaft. I thought it was odd that they didn't have any markings or brand name on them like all my old disks had but installed them anyway. At the track I could not get the clutch to lock up using my normal strategies. After two track nights I reached out to the clutch manufacturer and ask their thoughts. They said they had to switch the material out because they were having trouble getting the original material and that this new material would not take to being slipped very well.  So out with the first set of 26-spline disks and in with the correct material 26-spline disks. While I had the trans out I added an inspection/service hole. I've wanted one of these for a while. Now I can have a look at things and change the front cover shimming when needed (clutch wear). I hustled and got the clutch change done in a few hours on a Saturday. Hopped in the car and drove home. On the way home I did a 1-3 pull. When shifting from 2nd to 3rd the core plug in the back of the cylinder head popped out and dumped all the coolant. Thankfully I was only 30 seconds from home and coasted it there. Datalog showed nothing unusual and 2.5psi of coolant pressure. That plug has been in there since 1992 but I guess it worked its way out. Pulled the trans AGAIN and replaced the plug, JB welded it in, and made a brace. Also deleted the head drain I had added in during the bearing issue fiasco.  I am currently changing my boost control plumbing to make it cleaner. After that is done I'll make another attempt at getting past the 60.
    • Are you 100% sure this isn't tune related?
    • 140-150 across the board. At this point hoping the grounding harness fixes it. My grounds are all tied to the chassis and none to the battery. For SR and KA that’s never been a problem for me but had a few other guys here and Reddit who told me RB really like a very solid ground setup tied to the battery so going to try that next, I’m stumped if that doesn’t do it. Never had a car have spark and fuel and not fire off before. Only thing I can think is the spark is intermittent/weak because of grounds nothing else really makes sense at this point
    • I am having close to the same issue. Can you help me with what wire you grounded to get your pump to trigger?
