  • Replies 402
Posted Images
see ya'll there... knocking off work on time or a little early today looking forward to it
You right on how to get there? Let me know if u want to meet up along teh way or somethin...
yup 100% not coming tonight. car isnt ready STILL!!!!!! :D
Ian you suck! id be going down there n giving them an uppercut to teh face!
maybe ill throw trent from punchie at them.
i spoke to the mechanic, MAYBE tomorrow. but possibly monday. at least he knows what he is on about. explained a few things to me about what he has done and what he is going to do. thats all i want. i wouldnt be so pissed off if i didnt have to speak to the retarded owner. once this is all over i might post an unbiased saga of my stagea purchase and repairs.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
