I'll be in for next week.
PS. I for-filled my dream today....no I didn't get to Lay Angela Jolie.......but I did get to drive the 1992 Bathurst winning Winfield R32 GTR at pace at the Oran Park......mmmmmm.....still buzzing....and to think I have two more days of driving it
PSS. And yes I am gloating :D
Edited by Jetwreck
  • Replies 402
Posted Images
PSS. And yes I am gloating :)
Stop that glotting you bastard. :D
PSS. And yes I am gloating :spank:
You lucky MoFo, Craig!
I get to look at it every day, it's just a shame it's only in 1:18 scale... :down:
Sorry guys won't be able to make it this Thursday, it's my wife's birthday.
so bring her and we will take a cake :)
Yeh exactly, we always have carpark cake up teh coast for birthdays!
OK peoples, I'll be cruising up this week as per normal, but I have another quick message for you all:
If you're not already an SAU-NSW club member, sign up quick-smart and send me a PM as soon as you do, as we have our yearly SAU-NSW Christmas Cruise on this weekend!!!
Sign up for membership HERE!
Hey Nick, Its Brian
Might remember me from the SAU Show n Shine at Granville, Was with dad and his R31 wagon?
Also, from the Richmond Stag cruise couple o' years back! And bumping into you at Autosalon... (last year?*)
I have ended up buying a R31 Ti so therefore resigned up with a new username.. And my father is still yet to 'update' and purchase a Stag! im extremelly dissapointed!
I would come on the Chrissie Cruise if I had known of it earlier and put in for time off work!
Might have to join you guys one thursday Night for this cruise! I went up Old Pac last Saturday on a Suzuki Cappuccino cruise... Had no chance keeping up with those things around corners... Will be buying one soon, Should be fun.
Edited by BriansTi
no cruise for me tonight fellas... have to spend some quality time with the missus... just got back from brisbane
was a good cruise last thursday tho... good to meet some other stagea owners
Edited by Space Goat
I'll be there as per usual.
And hey Brian, yep I remember you. I should be at AutoSalon on Sunday at the SAU stand, so I might catch you then if you're heading in. Good work snapping up an R31, and hope to catch you on a Thursday night cruise soon!
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
