Item: JAYCAR Independent Electronic Boost Controller, Jaycar hand controller and xr6t wastegate solenoid
Item Condition: As New
Reason for Selling: Wanted something more simple
Price and Payment Conditions:$150.00 ono
Contact Details: PM on here for email
For Sale fully working
1x jaycar adjustable electronic boost controller
1x jaycar Hand Controller for Digital Adjusters w/ serial cable
1x xr6t wastegate solenoid
with this boost controller, you can set your boost map to be what ever you want! you have FULL controller over the boost curve
reason for sale. couldn't of been bothered to spend the time to tune the maps as perfectly as i wanted. upgraded to a profec boost controller for ease.
This hand controller is used for the mapping/programming of both Digital Adjuster kits. It features a two line LCD, and easy to use pushbuttons. It can be used to program the adjusters then removed, or left permanently connected to display the adjuster's operation. It is designed as an interface and display, and is not required for general adjuster functions after they have been programmed. If you have built and installed multiple adjuster kits, you will only need one controller to program, unless you want permanent displays for each adjuster function. Kit supplied with silk screened and machined case, PCB, LCD, and all electronic components.
Absolutely superb control over your turbo boost curve. It can be used in cars fitted with factory electronic boost control using the factory control solenoid, or cars without electronic boost control using a solenoid from a wrecker etc. It actually has two different completely programmable boost curves. This is ideal for switching between say, a race / street mode, or a performance / wet weather mode. Each boost map has 64 points able to be adjusted in 1% duty cycle increments. Boost curve selection is via a dashboard switch, and it is all programmed using the Handheld Digital Controller - KC-5386. Kit supplied with PCB, machined case, and all electronic components.
* Suitable for EFI and engine management systems only.
obviously it comes with a full case.
All up im chasing $150 ono + postage
i think this is a pretty awesome deal considering you buy these in a kit form and have to build them and i've already done that for you.
boost controller $59.95 unbuilt
Hand controller $79.95 unbuilt and
XR6t solenoind $ 45.
So thats a total of $185 and you still have to build them.
Item is also on ebay Here
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
