  • 3 weeks later...
Ill definately be at the next one though.
i heard bout urs, my new one goes in tomorrow, s'all good, now i got something that will handle the power of my new engine, now my gearbox is the weekest link, wonder how long that will last.
https://www.sau.com.au/forums/topic/24356-skirmish/page/2/#findComment-577045
well they are expecting 15 people but a few extras cant hurt too much
um due to my poverty stricken bank account i wont be able to afford to feed yas at little nerang dam (ie sasuage and bread) however feel free to bring along your own food as there is plenty of facilities up there, otherwise i think its best just to have a feed at the bp before we leave. (sorry but i donated the money i had for the food to prank for the forums)
hope to see yas all at bp coomera on saturday:cool:
https://www.sau.com.au/forums/topic/24356-skirmish/page/2/#findComment-588386
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
    • I said Garrett style. Not Garrett genuine. And something in the G30 550 range is what you want. Not those pokey little old fashioned T28 sized things. The intake ports in the head are small. There is little benefit in fattening up the runners and leaving ths actual ports small. Just run what you've got. And on the subject of Nistune vs Haltech etc..... You know you can control the transmission with decent standalone ECUs these days, right? No need to keep any of that old Nissan bullshit. Don't get me wrong - I use Nistune on my Neo. But it is a DET, so the number of bodges and workarounds I had to do to make it work in a chassis without ABS, TCS, etc, is quite small compared to the herniated arsehole you will have trying to make it work on a motor that doesn't have some of the things that the turbo ECU wants to see. Just easier to bite the bullet and go aftermarket outright.
    • Hmm. Only when the f**king thing is actually working. Still can't find the leak. And that's with dye being put in the last 3 times!
