Hi All,
Several bits and pieces for sale from my old GTS-t. Get 'em while they're hot! :)
ITEM 1: First up is a set of standard R32 GTS-t wheels. They're in really excellent condition (just grubby) with almost brand new Pirelli tyres (95%+ tread).
Stud pattern is 5x114.3, and the wheel size is 16"x6.5" +40. Excellent for track days with the near new tyres. Or a really nice addition to your R31.
I'm looking to get $500 for these. That's cheaper than buying the tyres by themselves. :banana:
ITEM 2: Standard R32 GTS-t springs. Great condition, nothing to worry about. Clear those defects! :banana:
Give me $50 and they're yours.
ITEM 3: Instrument cluster for an R32 GTS-t. This is out of a series 2, so it's got the grey faced dials. Also comes with a white LED backlighting pack from Dan's for sale thread on here. Working perfectly, has 141,xxxkms on the dial.
Take it away for $80.
ITEM 4: R32 GTS-t speedo cable. Nothing wrong with it. Original one that came with the car, so it has a slight amount of 'wobble'. Works fine.
Yours for $30.
ITEM 5: Very basic turbo timer. Brand is 'CaliTec' and I believe it's Australian made. Switchable between 1, 3 and 5 minutes. Can be fitted to any vehicle. Working fine when last removed.
Going to a good home for $20.
That's it, for now. I've got an R34 GT-T intercooler that may go up soon. As well as a TurboSmart boost controller, if anyone is interested.
At this stage all items are pickup only, but I'm prepared to talk postage with those who are really desperate (for some of the smaller items).
Contact me via PM if you need to, or post in this thread as I'll be checking it as often as I can. More pictures can be arranged if requested. I'm a trusted trader on SAU, and plenty of other online communities. Feel free to ask any questions. :banana:
Cheers!
Ryan
Edited by HuH
https://www.sau.com.au/forums/topic/243653-r32-gts-t-parts-accessories/
It's a TurboSmart job. Single stage switchable controller, so you can have stock boost plus high boost and select between the two. It basically looks like this, just a bit bigger:
SPEEDO CABLE IS SOLD.
I'll get back to you about the boost controller.
The intercooler is a standard R34 GT-T intercooler. Direct fit into an R33 GTS-t. It came out of a 2001 model '34, and it's in great condition.
  • 3 weeks later...
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
