I had all my belts replaced recently (car's a 34 GTT) and next few days the belt were squealing so i took it to a local mechanic who tightened them and that stopped the noise.
however a couple of weeks later the squealing has resumed on every single cold start .. the belts are pretty damn tight (imo feel a bit TOO tight) and I don't wannt take it to the local mechanic again as the bloke's very young and might decide to tighten them even further as the only solution adn this might damage the bearings etc I'm afraid.
So anyway I got some belt dressing spray which is supposed to make the belts grip better and not squeal ..my question is how do I apply this stuff? do the belts have to come off ? I mean it's like a hairspray can and pretty big so its impossible to reach the belts from under the hood. Also I can't apply the dressing on the entire belts as they can't be turned when the car is off (or can they ??) so I'm kinda stumped .. anyone done it? any tips?
To my knowledge the 'belt dressings' are not good for belts. I think they basically chemically soften (melt) the belt rubber so it grips more. These things are only a band aid fix and one application may not fix it or ever for that matter. This isn't the best for the belts either and you can end up with gooey rubber on the pulleys (or anything else it flies off an hits). Typically a squealing belt is the sign of a tension issue.
What sort of belts have been installed? Is it every belt that is squealing or is it already a bearing? Do you have the air con on when you start it up?
Here is some info on Auxiliary Belt Tensioning that may be useful.
R33___Auxiliary_Belt_Tensions.pdf
Edited by Fry_33
By is it the bearing already I was suggesting it could be a bad bearing but I guess it would be constantly making a noise if that was the case.
The meter will have a Newtons or kg scale on it (maybe both). You basically just reset them and then just press down until it clicks. Then read the tension on the scale. The place you test it is at the locations of the black arrows. Seeing as how the belts are already on and have been ran in you want a tension value within the Adjustment range in Newtons or kg in the {} brackets.
The info I put up is for an R33 but it should be pretty close, maybe even the same.
dude i had the exact same problem all i did was tighten my alt belt till it was tight cos it loosens after a lil cos the belt has to settle in so just tighten it and it should be good all u gotta do is undo the bolt and wind the adjuster
the alternator belt is pretty tight already ..too tight IMO. There's only about 2-3mm flex in it when it should be 8-12mm from what I've read online. I've also found some info online that says it can also squeal if it's too tight
I'll try loosening it up a bit .. will let yous know how I go.
you just spray it on the belt with the car idling/running, it's that simple.
will quiten them up, usually only needed with old belts that have gone hard to quiten them as a bandaid fix, kind of masks the slipping rather eliminating it from what i can gather, once the lube dries up in a few weeks, you will need to spray more and go around a never ending circle.
what brand are the belts?
i've never had a problem with most brands, but genuine belts can offer some extra peace of mind for a few extra bucks also.
if you are 100% sure they are torqued properly, you might have an accessory load (alternator/water pump etc) or idler bearing that is causing drag due to faulty bearings, but i would double check the belt quality and torque setting first as nine times out of ten this is the problem, especially your decription of cold start only.
there is a fair load on the alternator belt, it has to spin a fully loaded alternator after initial cold start, plus the viscous fan is locked up on the initial cold start until the fluid flow inside and releases it plus the water pump, so it does need to be tight and some crap belts tend to stretch a little, or more so settle in, so it may take a couple of retorque to get it correct.
if it was power steer, it would squeal as you turned the steer wheel when cold. likewise if the aircon is off, no load is on the aircon belt.
so alternator belt deff the one to look at.
Edited by RB30-POWER
    • f**king around with the bro
    • Ludenham   44.2 tops day no issues
    • Then today, I went to visit a man with an r33 hat Peter and Road and Race sorted the alignment. As it is being set up for general track/hillclimbs etc it has a heap of caster (7o), less camber than I am used to (1o front and 2o rear, as the caster looks after that in turns without the braking downsides), 3mm front toe out and 0 toe rear. Will see how that goes and track tyre wear to see if it does need more camber, but adjsustment is also limited with nismo arms and adjustable bushes at only 1 end. It does have a bent inner tie rod on the driver's side front but as it came up within spec I'll just leave that as is. So, that is getting close to my chapter of this story....could of tidy ups then a shakedown in early October before it finds a new home.
    • So, it went to Unigroup for a run in and tune on Friday, everything went (generally) well. In terms of fixes, the engine was good and there were no leaks. It needed plugs (I hadn't checked them because the coil pack cover was on a new engine and I couldn't imagine they weren't new.....but turns out the temporary plugs to just keep it sealed up were in there.....new plugs gapped to 0.8 and it was fine from there. Also, there was a little preload on the clutch slave which caused some slip. I haven't had the box off so I don't know what the clutch looks like; my guess it is brand new and the pedal had not been adjusted....backed that off a bit and it held fine. Last thing will have Dose crying....the idle especially when cold is a bit difficult between the cams, forward plenum, atmo blow off valve and an 80s air management system. It is fine when hot but a little uneven when cold, will see if I can sort or at least improve that one cold morning. Other than that, tuning went fine. It made 245 but was pulled back to 227 which 2 opportunities to improve in future. 1. The factory CAS is not great and was jumping around at high RPM, so Mark took 2 degrees out up top (that is why it stops making power and lost 20kw). Very safe this way and the extra power is available but will require a more modern ECU and better cam (or even better crank) sensor 2. The 2871 in factory housings is very big for a low mount, and the internal wastegate is too small, so it was creeping from mid range all the way to redline....the duty cycle on the boost controller is turned down a little for safety. That is much harder to fix, it would need a large external gate and that would require a whole bunch of other changes, so it will go as it is for now. It feels nice and healthy and safe, so should be good for about a billion laps like this.
    • what sort of caliper are they? If they are a slider and you gave everything a good clean, you might need to regrease the pins. My guess though is they will come good after some abuse as suggested above
