Hey all,
don't know if anyone has experienced this one before.... I've got a bleed valve on it to bring it up to about 10PSI but through the rev range it only hits to 10psi after it revs past 4000rpm. anything below that, its still at the stock 7psi. Can anyone help with any 'constructive' :D suggestions to fix this problem???
https://www.sau.com.au/forums/topic/24391-boost-issues/
Bleed valve is a cheap way to increase your boost, but not as reliable as Electronic Boost Controller one. solution perhaps is to get a proper electronic boost controller like Apex'i AVC-R or HKS EVC.
I have a bleed valve as well, still saving money to get an EBC.
https://www.sau.com.au/forums/topic/24391-boost-issues/#findComment-520586
for $135 you can get the Turbo XS High Performance Boost Controller (HPBC)
it has 2 adjustments.
1 = increase boost
2 = reduce or eliminate wastegate creep.
the second adjustment is what makes the boost come on earlier and harder.
R33's standard boost is 7psi.
R32 is more like 9 or 10psi standard.
as mentioned, if you put a boost controller on, you need to use that INSTEAD of the standard boost solenoid...
https://www.sau.com.au/forums/topic/24391-boost-issues/#findComment-522609
Originally posted by Hicks
Probably because the stock turbo cant make more than 7 pounds of boost below 4000 revs.
i doubt it as the r33 series 2 spools up real quick coz of the plastic comp wheel.
at the moment with my half complete project i can get 12psi boost at just under 2000rpm with lightened flywheel, adj cam gear and pfc tune.
Legend
I think you have your stock boost solenoid still connected in the line. Bleed valves are cheap and nasty, dont ever expect good boost control with them.
https://www.sau.com.au/forums/topic/24391-boost-issues/#findComment-523152
Originally posted by legend
INASNT: me thinks I'm going to have to invest in an EBC...:) $$$
predator666: nope, got a greddy boost gauge :)
yes you better. I think my greddy profec b spec 2 also helps bring boost on early!! Only think with the spec 2 is that you have to *** around with it alot to get it to work the way you want
https://www.sau.com.au/forums/topic/24391-boost-issues/#findComment-524336
yer.. with my profec it comes on at about full boost at about 3500rpm from what i remember.. not bad considering just S-AFC, zortst, cooler combo. it'll make a difference..
really depends on the bleed valve.. some are worse than others..
https://www.sau.com.au/forums/topic/24391-boost-issues/#findComment-525744
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
