Improve fuel economy
Maintain high voltage
Fatter sparks
Increase horsepower
Their website can be found at
http://www.sun-auto.co.jp/pro_inazma01.htm
Use this translator http://world.altavista.com/
Insert the website to be translated and choose Japanese to English.
Selling for AU$450. Test try available to serious buyer only!
Email only please [email protected]
https://www.sau.com.au/forums/topic/24403-hot-in-japan-hot-inazma/
Fatter sparks
Increase horsepower
I have tried it and it improves mid range response. I tried it on Holden Barina, Alfa Romeo, Toyota Soarer and Silvia. Revvs up faster and heaps of difference on turbo cars. It works like the HKS twin sparks but alot cheaper.
Well let me give a better explanation. It maintain a constant voltage at the spark plugs. This is regardless of workload on alternator. The improvement is even more significant if you had stereo systems in your car and it will still keep that voltage up at 13+v
Sure if you can come up to brisbane. Here's some pics to show you how easy it can be connected.
http://www.geocities.com/sil21jun/Hot_InaZma1.html
http://www.geocities.com/sil21jun/Hot_InaZma2.html
Connect the red and black cable across the terminals of the battery and its all done!
Email me to arrange for a test trial.
EnricoPalazzo. True I totally agree with you. All I need is a couple of weeks and I can show results with dyno sheets. To be honest and based on the feeling of my butt. I would say it has not much or no significant increase to the peak horsepower gain. But my butt tells me that mid range has more torque and smoother. Ranging from 2000rpm to 4000rpm. Prior to installation, my fuel consumption was 350-380km and after installation went to 425km (at least). No one can feel a 3hp gain with their butt. So I predict it will be a good 5-10 hp gain in the mid and mild at peak.
  • 1 month later...
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
