Hey all,
My car Currently Needs a Power steering Issue Fixed and im talking to the guys at tenagah, But they suggested i should Scrap HICAS..
So Should I get the Cars Back to Full working standard or Scrap it?
So yea I like Hicas But Peoples Experiences With it and so forth Let me Know, Pros with it, Cons with it Vice Versa
THANKS :blink:
Benson
https://www.sau.com.au/forums/topic/244322-to-hicas-or-not-to-hicas/
Just scrap it. Everyone I've talked to who's got rid of it was the best thing they've done. Can't remember why it's so good, but no one has complained!
Plus you'll save about 10kg or something without the lines. Any weight saving is good in my book.
Rhys, 33 hicas is electric so there are no lines. Any weight saving is negligible. 32 where the hicas was hydraulic if you disconnect it at the front of the car and pull all the lines etc then the weight saving can be 25kg from what ive heard.
Everybody hates Hicas however another way to look at it is, Nissan spent millions designing the system to work....so it cant be that bad.
Having said that, i took it out of mine :blink:
Hicas was designed to be a sort of 4 wheel steer.
Great for parking, BUT
if you are on the track it will try to correct your opposite lock until you spin off trying to correct being corrected and so on
Ditch it only if you put a locker bar in, just in case you hit a kerb and knock the wheel out of alignment.
HICAS does not work for parking.
HICAS only operates over 80kmh and only about 1deg either way when 'X' amount of steering lock is applied.
It is a safety feature for people that don't know how to drive, the theory is if you come too hot into a corner it induces understeer as Nissan figure that was a lot safer for novices drivers than oversteer.
The problem I found with HICAS is the unpredictable snap oversteer when pushing my car hard.. it was also quite hard to change directions when doing 2nd gear burnouts on the brakes as the car just wanted to crab down the road with all wheels pointing in the same direction.
So, im summary: it is not a turning or parking aid, it is a safety feature.
When pushing my car to the limits I want only me in control, not some computer that thinks it's doing the right thing. Best $80 and a couple of hours I've spent on my car!
Having said that, i took it out of mine :)
My bad :D. Now that I think about it, I did read that on an R32...
Either way, ditch it.
heres my experience with it...
Was going through Safety Bay roundabout in Rocko, the roads were still wet from rain earlier but it wasnt raining anymore. No one else was on the road and I know this corner like the back of my hand. I had 2 chicks in the car with me and I gave it a boot just as I was exitting and straightening up the roundabout so it was safe, it lost a fraction of traction but didnt slide or anything like that, just a tiny skip. HICAS thought I was losing control and it reangled my wheels to (supposedbly) counter this.
Anyways, what it actually ended up doing was swing me literally lane to lane. As I was in shock and never experienced it before I was trying to counter the HICAS which made it swing back into the other lane again. My friends in the car just both looked at me with a blank stare because they knew the car was what made it switch the lane first.
I didn't wana experience that ever again, was pretty scary especially with 2 box curbs on each lane, not to mention im lucky no other cars were around. Next day I went to J-Shop and got them to fit me a lockbar in and I havn't had the problem again.
And I think in the 34s you can lose close to over 30kg if you remove everything with it, but apparantly its a big job to do that.
Edited by Magic
Oh man that would scary as hell... Would only be worse if there were more cars around...
I have a Hicas Lock bar installed. I don't believe the system was removed.
Edited by Haunter
HICAS works in two ways - at lower speeds (above 25 or 40kph from memory) it steers opposite to your front wheels, at higher speeds, above 80?kph, it steers in the same direction as your fronts - total steering is only around 1mm, but it enough to make the steering feel more lively when cruising and going a bit harder, but not when you go really hard.
As you change speed through corners, the steering can either kick in (at lower speeds) or swap from opposite to steering the same direction as the fronts - this is really, really bad for hard driving.
You will feel that the steering is slightly heavier at first once you remove it (only slightly), and you will need to remove the HICAS light bulb from the dash (or it will give you the shits)
If you just cruise around and go for the occasional 'light' punt - HICAS is fine
If you drive hard (track, MC, or similar) piss it off - all race cars remove HICAS, even back when they raced 32s at bathurst - for good reason.
It would generally be cheaper to remove HICAS than to replace it.
And lastly - any weight saving is good, even a few KGs.
My thoughts (and I have driven both with and removed and driven without)
I'm not a fan, because no other car I drive has it so it make driving the skyline weird when I corner with my foot down.
plus when it is wet, and your trying to turn at a t-junction quickly because there is busy traffic... it's dangerous.
Pretty sure it does nothing at low speeds, it's not like the 4WS systems of other cars (such as the mazdas etc)..
it does work at low speeds because if i slow down for a turn and then gun it round the bend quickly it brings my back end round nicely, sometimes im not sure if it is the HICAS or me losing traction. i quite like it but then i have not had the car going hard round a track or a skid pan yet. am booked in to take it on the skid pan at AHG next month so i will have a better idea then and make my mind up wether i still like it.
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
