I like the meshies with the little bit of dish
the new mags are ok, but the colour doesnt suit - powdercoat into white would look ace, or a smokey grey with pearl clearcoat
keep the mags but powdercoat them a different colour
....... never look back I say
Thanks for all the replies.
It's funny, in the flesh the AVS look much better than the Volks. People at work thought the same today also except for the colour. The picture just doesn't do them justice. I've never been a huge fan of white rims, plus I don't want to have to clean them every 5 minutes so I'm going to get the AVS rims powder coated with a dark gunmetal grey tomorrow and see how it looks. It's cheap as so if I don't like it I'll probably just sell them. Anyone with photoshop feel free to have a play with colours!
Thanks,
Matt
sorry mate the first ones for sure,what were they thinking designing the second set,they may have purpose but look like rubbish,definately look like they belong on a sylvia or something that has no taste or design,id change back unless your using your car for drifting etc,i guess thats what the rims are made for
Thanks,
Matt
ive seen quite a few of both the AVS and volks, i much prefer the volks. but its up to u man, if u like the AVS's more then keep them, that's all that should matter.
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
    • Add more solar panels to the array. Call the electricity company and tell them you're moving out... Live off grid electric wise
    • Hi Jasmine. How's the war going?
    • I'm extremely suspicious of the VPP stuff. Best I can tell, you surrender any and all control of your panels and battery to the VPP, because there's no way that anyone could write a sufficiently useful set of "rules" as to how much you would be willing to let out of your export meter at any given time. If one of your main interests is to have enough in your battery every evening to get you through the night without having to import, you could easily find yourself with nothing in your battery at the end of the day, or part way through the night, and then be paying import pricing instead of paying nothing. I cannot see how this cannot come to pass.
    • majority aftermarket is an10 yes, but majority of OEM is An12 r35 OEM cooler lines at close to an 12, the hard line that car uses is almost 20mm  Porsche OEM is also AN12   i figure, if our power levels are close to 1000hp, then AN12 should be a must if many OEM standard power vehicles use AN12
