  • Replies 46
Joondalup central, the best place to be get to walk to awesome night clubs like dusk and maxx.....
LOL r u serious? joondalup has crap night clubs, the maxx and dusk = fully sick c**ts that wanna fight and get made by bouncers
and the pubs are just a sausage fest lol
Of course im serious joondalup night clubs are the bomb, especially dusk on a sat night it goes off theres like twenty people in there and there all dudes.....score.
lol or the odd weekend were you get the single miserable cougars that are hitting there 40's wearing supre specials and have saggy breasts hanging out while they try to get with the losers that have just hit 18 and are looking for a "fight"
all in all joondalup is a big "FAIL" night spot :P
Gotta love the cougars they make the night, if you cant pick one of them up you may as well go home and never come out again.
OMG, My mate is soo seeing your post, he loves Dusk, in fact I'm pretty sure he is there right now :laugh:
Too much information... :laugh:
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
