Originally posted by R33man
I was recently quoted $4000 for supply and fit (including dyno tune) of a Power FC computer and boost controller.  Is this a good price or should i look elsewhere.  :)
:bahaha: can u say RIP OFF??
U can buy one new for $1400 with hand controller, to install takes about 10 mins if u know how to use a screw driver and socket set. Proper tune depending on mods you got about 2 hrs.
All up i think u are paying around $2300 more than u should.
https://www.sau.com.au/forums/topic/24467-power-fc-cost/#findComment-523164
Originally posted by Ronin 09
look out guys, customs are getting smart. The last 2 packages from greenline i've received have been taxed, and they've somehow got the exact cost of the items as per greenline's site...
How much tax did u pay on the parts??
Customs must be reading the forums to now.
https://www.sau.com.au/forums/topic/24467-power-fc-cost/#findComment-524328
Originally posted by hungry6
mine is costing me a fair bit more to tunecause i'm looking for the every last horses in the motor , including the one hiding behing the trees.
One word : DETONATION.
If you try and extract evey last pony, as soon as the air temp changes, or you get a slightly off batch of fuel etc, your check engine light starts flashing away at you, ignore it and do a rebuild.
Its a real pain (talking from experience). If you go for a more conservative tune, it is more likely to give you a longer, hassell free life.
0.02
https://www.sau.com.au/forums/topic/24467-power-fc-cost/#findComment-524718
Steve...of course detonation and exhaust temp would be taken into consideration. In fact a lot time is usually spent tuning at the track (if the pockets are deep) where temp is hot and car is being pushed hard...would have thought you had done that with your car too.
P.S....why would you ignore the engine light flashing at you?
https://www.sau.com.au/forums/topic/24467-power-fc-cost/#findComment-525269
4 Doorz, the post just set off alarm bells, so injecting a word of caution. Every last pony insights visions of max hp on a dyno - to me anyways. I had someone do a 'get every pony possible' tune, and it wasnt long before I took it somewhere else and got a retune.
I completely agree with you, WRT a good tune. My car doesnt get track tuned, but it does get a good workout on the street. And yes it does cost extra, but well worth it IMHO.
Check engine light - some people dont keep an eye on their check engine light, and usually pay the price.
https://www.sau.com.au/forums/topic/24467-power-fc-cost/#findComment-525658
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
