Originally posted by R33man
I was recently quoted $4000 for supply and fit (including dyno tune) of a Power FC computer and boost controller.  Is this a good price or should i look elsewhere.  :)
:bahaha: can u say RIP OFF??
U can buy one new for $1400 with hand controller, to install takes about 10 mins if u know how to use a screw driver and socket set. Proper tune depending on mods you got about 2 hrs.
All up i think u are paying around $2300 more than u should.
https://www.sau.com.au/forums/topic/24467-power-fc-cost/#findComment-523164
Originally posted by Ronin 09
look out guys, customs are getting smart. The last 2 packages from greenline i've received have been taxed, and they've somehow got the exact cost of the items as per greenline's site...
How much tax did u pay on the parts??
Customs must be reading the forums to now.
https://www.sau.com.au/forums/topic/24467-power-fc-cost/#findComment-524328
Originally posted by hungry6
mine is costing me a fair bit more to tunecause i'm looking for the every last horses in the motor , including the one hiding behing the trees.
One word : DETONATION.
If you try and extract evey last pony, as soon as the air temp changes, or you get a slightly off batch of fuel etc, your check engine light starts flashing away at you, ignore it and do a rebuild.
Its a real pain (talking from experience). If you go for a more conservative tune, it is more likely to give you a longer, hassell free life.
0.02
https://www.sau.com.au/forums/topic/24467-power-fc-cost/#findComment-524718
Steve...of course detonation and exhaust temp would be taken into consideration. In fact a lot time is usually spent tuning at the track (if the pockets are deep) where temp is hot and car is being pushed hard...would have thought you had done that with your car too.
P.S....why would you ignore the engine light flashing at you?
https://www.sau.com.au/forums/topic/24467-power-fc-cost/#findComment-525269
4 Doorz, the post just set off alarm bells, so injecting a word of caution. Every last pony insights visions of max hp on a dyno - to me anyways. I had someone do a 'get every pony possible' tune, and it wasnt long before I took it somewhere else and got a retune.
I completely agree with you, WRT a good tune. My car doesnt get track tuned, but it does get a good workout on the street. And yes it does cost extra, but well worth it IMHO.
Check engine light - some people dont keep an eye on their check engine light, and usually pay the price.
https://www.sau.com.au/forums/topic/24467-power-fc-cost/#findComment-525658
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
