Hey guys got heaps of stuff for sale for an almost complete GTR engine setup from the halfcut. Its as follows:
1. RB26DETT Head and Block in one piece, has a blown headgasket and some issues, would suit a rebuild or someone sourcing the head or the block selling as one. You get everything except the accessories attached like turbos, plenum, intake etc - $1500
2. GTR Gearbox in good working order - $700
3. R32 GTR Twin Turbos in good working condition minimal shaft play - $400
4. RB26 Start motor - $170
5. Remapped GTR ECU looks from an item from japan, unknown maps - $200
6. Stock GTR injectors - $250
7. GTR Fuel Rail and regulator - $150
8. GTR Coilpacks - $120
9. RB26 Alternator - $170
10. RB26 Plenum - $300
Prices are negotiable. These are the main items at the moment, i will update as i pull more parts apart. Pickup preferred from sydney area
Contact me via PM
Edited by phantomgtr
https://www.sau.com.au/forums/topic/244819-r32-gtr-rb26-engine-parts/
Contact me via PM
Ok mate, no worries. I'll do a bit of a search, and ask one of my mates, but if they do fit, Im nearly certain that I will buy them on the weekend, maybe even tomorrow, if your not too busy. How far would you say you lived from Chatswood??? Are you able to pm me your mobile number so Im able to get in contact with you a little easier, and if everything does work out, we'll try work out a time to meet up and a price???
Thanks haeps mate
pm sent.
more items for sale
11. R32 GTR Aircon compressor - 120
12. R32 GTR Power steering pump - 100
13. Clutch and Flywheel may soon come avaliable unknown items at this stage as haven't taken them apart
Hey mate,
Might be keen on the injectors, do you know if they're ok to use in a RB30et??? Where abouts in Syd do you live also???
Best regards
yes they do,both top feed,but you need to make up hose tails as they are an "O" ring fit in the rb26 rail.....easy to do,cheap
Edited by Z24O
UPDATE
TURBOS SOLD.
ALSO HAVE TRANSFER CASE AVAILABLE AND SUMP if someone just wants the head and block.
OK guys parts are all ready, let me know what you need and prices are negotiable to a reasonable extent.
Price Drop Need the parts GONE !!
1. RB26DETT Head and Block in one piece, has a blown headgasket and some issues, would suit a rebuild or someone sourcing the head or the block selling as one. You get everything except the accessories attached like turbos, plenum, intake etc - $1200
2. GTR Gearbox in good working order - $600
4. RB26 Start motor - $150
5. Remapped GTR ECU looks from an item from japan has had the speed limiter lifted off, boost lifted, fuel maps changed - $150
7. GTR Fuel Rail and regulator - $100
8. GTR Coilpacks - $100
9. RB26 Alternator - $150
11. R32 GTR Aircon compressor - $100
13. Heavy Duty /Single Plate Clutch (to be confirmed) and Lightened Flywheel - $400
14. Transfer Case for Gearbox - $250
15. Front shaft - $100
PRICE DROP AGAIN and the avaliable items left !
1. RB26DETT Head and Block in one piece, has a blown headgasket and some issues, would suit a rebuild or someone sourcing the head or the block selling as one. You get everything except the accessories attached like turbos, plenum, intake etc - $1000
2. GTR Gearbox in good working order - $500
4. RB26 Start motor - $130
5. Remapped GTR ECU looks from an item from japan has had the speed limiter lifted off, boost lifted, fuel maps changed - $100
9. RB26 Alternator - $130
14. Transfer Case for Gearbox - $200
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
