Hey guys, just a quick noob question,
I have bought a set of WEDS SPORT SA-90 Rims
Im not that educated when it comes to offsets and shit,
Just wondering how many inch wide these rims are? or do they vary in width? they are 17s
and does anyone know the offset? or does that vary?
cheers
https://www.sau.com.au/forums/topic/244860-weds-sport-sa-90/
umm how would we know what size offset or diameter your wheels are? SA-90s would probably come in at least 30 different sizes... I have a hot tip, ask the seller before you buy them, or look at the wheel for the size sticker. failing that measure them...
quite frankly i didnt give a shit what the offset n width was when i bought them,
i bought them off my mate who is a manager at ian diffen, and they are 2nd hand from a trade in,
i got four rims with tyres 90% tread all up $250, i knew they where the right stud pattern so i got em coz i could sell them for a profit
well then why the fk are you asking me what size they are? I'll tell you what. if you can tell me what size my shoes are I'll tell you what width and offset your wheels are.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
