I think we really need a skid pan here!
We could have so many events there, eg. motokhana's, drift, go to whoa, burnout's, whatever! Even just "open" nights during the week to get it out of your system, and it would also be a good place to catch up and have a chat with free entertainment.
It would save all the "hoons" doing it on the street. Especially if it was low cost.
And it would be awsome if it was central, not miles away. You wouldn't need alot of land.
Does anyone know who you would have to speak to to get the ball rolling???
What's everyones view on this?
Edited by Fabs_32
https://www.sau.com.au/forums/topic/244900-skidpan-in-sa/
Problem is the government in this state is run by an ex cop (rann) and all he see's places like this drag strips etc etc as is encouregment for "hoon" drivers so doubtful you'll get any government support for anything like this....
All great ideas in theory though, pity they can't see the response they get in otherstates for places like this though, all they wanna do is bring in new laws all the time instead of trying to fix the issues....cheaper that way
https://www.sau.com.au/forums/topic/244900-skidpan-in-sa/#findComment-4262512
if my parents still had there 4 acre property at lewiston, id invite you all round for
some grass drifts :P
no seriously, thats how i learned to drive!
once ya get the sideways control right, the rest of it is easy as piss! lol
god i miss that property, was like my own motorsport park :)
but yeah, i doubt this will ever happen either, there is the massive aami advance drivers course area at west lakes,
if it was going to happen, it would have happened by now.
adelaide = behind the times. get over it.
https://www.sau.com.au/forums/topic/244900-skidpan-in-sa/#findComment-4262680
Any more info on this driver training at west lakes? Looking for something like this (skid pan/defensive driver training course/etc).
At the Learner Driving course place in Palkholme there is a skid pan but looks as if it hasn't been used for years, its blocked off by those huge rocks and has plenty of weeds growing.
https://www.sau.com.au/forums/topic/244900-skidpan-in-sa/#findComment-4262846
some grass drifts :(
god i miss that property, was like my own motorsport park :D
snap.............my brother has almost 3 acres out at Lewiston
https://www.sau.com.au/forums/topic/244900-skidpan-in-sa/#findComment-4263257
hahahahha +1 for rally bashing. Ah the fun that can be had with a sub $500 car and some private land :D :D
Edited by AndrewJZX100
https://www.sau.com.au/forums/topic/244900-skidpan-in-sa/#findComment-4263449
I feel strongly about this so I'm happy to work at it, but I just wouldn't know where to start, who to talk to, etc. Anyone tried to do anything like this before? Who do I have to "convince" to make this happen?
It's a pity the government doesn't comprimise/talk with car enthusiasts to try and resolve/minimise hoon behaviour.
Edited by Fabs_32
https://www.sau.com.au/forums/topic/244900-skidpan-in-sa/#findComment-4266828
    • How much have you lowered?  I had 350Z springs in the rear and was able to pull the camber into factory spec with the factory arms on the rear, obviously the front ran negative camber as it isn't adjustable, but rotating the wheels regularly evened out the wear.
    • Either the installer needs to come back, you need an auto electrician, or you need to learn automotive electricals yourself.   First step Id look at is where that big thing came out of, is there still things unplugged at that location? Maybe they just forgot to put a relay in or something?
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
