With much sadness the 4 Door will be put up for sale to make way for another GTR. This car was originally built by Martin Donnon at Willall Racing as part of "Project 11's" featured in 11 issue's of zoom magazine. Funly enough they never acheived a 11 second quarter. I did however =) 11.8 at WSID. The car setup works extremmely well. It runs a rare 5 speed Auto Nissan trans which also has a lockup high stall which gives 6 ratios! As you can imaging this makes the car very responsive at any rpm and also give suprisingly good fuel economy. During the original Build the transmission was fitted with a modified value body and kevlar clutch discs by Mike at MV automatics here in Adelaide. It was a very nice setup ,but now is better still. I've had the trans fitted with high performance valves and new kevlar discs during an overhaul earlier in the year so the shifts are now instant. The 3500rpm stall ensures lag free launches and multiples the torque to the extent you can pretty much fry the tyres at will at most speeds. When cruising however the lockup kicks in and she cruises just like the factory wanted...it really is an absolute pleasure to drive. The motor was stock and was rebuilt with new bearings, rings, 33 crank and turbo's. Standard bore 86mm CP forged pistons have been fitted to ensure a very reliable package. The car is also fitted with a full GTR rear cradle, (diff,etc), GTR front support for the R33 GTR front bumper and r32 GTR brakes all round.
Other upgrades are as follows:
R33 GTR front seats
Triple gauge dash cluster (white nissan)
Series 2 tail lights and center garnish
Full hard pipe kit (turbo inlets, turbo outlets, smooth transition twin turbo merge pipe)
Apexi filters
R34 AFM's x2
Apexi PFC
Apexi N1 Dual and std exhaust
boost set at a lazy 14psi max
Momo Evo Millenium style steering wheel
HSD damper and height adjustable coilovers
18" ROH 3 piece Strada wheels x4 + R34 std wheels x4
I haven't put the car on the dyno since I got it, however the tune has been adjusted each time the engine has been modified. I have many different tunes and data log files to go with the car. The current summer tune was comlpeted in the last month, runs 12.6:1 AFR and no knock what so ever.
The car has had most of the performance upgrades completed after my run at WSID and is now considerably faster. I won't give you a estimate of power, but I'm sure you can work it out from the time it has run
The car is currenlty registered and cleared through Regency for the engine change(papers included) so no need to worry about getting a canary.
The car will be ready for sale in the next few weeks. I originally purchased this car at a steel for $15,000 a year ago. After the additional mods and adding up how much I could part the car out for: I will be looking for $15,000.
Contact:
Matt
0413023669
or
Troy
0413307661
ps. the car will be at Mallala on Nov 20.
Edited by BoostdR
just wondering how good is the fuel economy on this?
Yeah it'd be fine as soon as you went into boost range. Then you could watch you fuel gague bungee jump. lol
  • 3 months later...
The car is in storage and hasn't been driven since my Brother-in-law got his GTR. He has just bought a house so if you through him offers you may get a real bargin. It does need some attention
-real bumper is burnt from the N1 dual exhaust (new silver bumper supplied, just fit)
-A wire from one AFM to the PFC is intermittent, just needs the break to be found
-two of the ROH rims have been dented and require re-rolling.
-DVD/SAT NAV has been removed but will be supplied
The engine is extremmely fresh and very clean any test welcome(leak down, compression, turbo play, headgasket, etc)
Get in quick
in terms of fuel economy, for those interested. im pretty sure this car was used for an article that involved tuning specifically for economy, and they got it from mid 14's down into the 11's (litres per 100km).
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
