WTB: Stock GT-R Exhaust and Stock Shocks/and or Springs
stockgtr , im not interested in the pipe but would like to know the diameter of it , is it the twin dump pirethat u have ?
stockgtr , im not interested in the pipe but would like to know the diameter of it , is it the twin dump pipe that u have ?
hi,
i have one nismo front pipe for GTRs(twin pipe), asking $300
GTR34 standard cams, asking $100
GTR34 standard shocks + springs, asking $280
GTR34 standard ECU, asking $300
call me on 0413022364 if u are interested, thanx
cheers
thx mate , i just wanted to know what size the stock pipes are .
very hard to find one with stock pipe
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
