genine jap kits are best quality and fitting, but if you cant find any, then places like viva garage or cartoys etc, might have something you like or be able to point you in the right dirction... IMO, the best rear bar ever fitted to a 33 was on mark phillips old WHIPLASH... hawwttttttttt :blink:
https://www.sau.com.au/forums/topic/245751-body-kits-r33/#findComment-4274387
yeah i know they suck, and are mad overpriced, but where else can u get body kits in SA other than ebay or viva... autobarn are crap, everywhere is crap these days unless u buy direct from japan, and with the exchange rate atm... need i say more.....
https://www.sau.com.au/forums/topic/245751-body-kits-r33/#findComment-4274438
Find something you like and import it yourself. Who cares what the exchange rate is atm, you don't think the retailers will get that out of you anyway in the sale price? If jap fits best, go for jap. :D
https://www.sau.com.au/forums/topic/245751-body-kits-r33/#findComment-4274695
R33 GTR front lip pic doesn't work psiparts.
We have just put up some new products and thus don't have pics yet, this should be sorted in the next few weeks.
where abouts down south are you mate?
Our warehouse is in Dandenong.
https://www.sau.com.au/forums/topic/245751-body-kits-r33/#findComment-4277047
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
