  • Replies 61
Hi all :)
Give Ian Luff Motivation Australia a call on (02) 9829 5399 to place your booking
SAU price is $255.00 Don't forget to mention it if you want the discount ;):)
Boz,
How noob friendly are these days?
I wouldn't mind doing it, but don't really want to be spending the day moving out of the way. Especially if the majority of cars are as fast as you've said.
Cheers
Bobby
The luffy days cater to all type of cars and drivers..
It's all about driver training.
Last one I went to was good and there were alot of newbies there. This day should be the same :)
The fast guys are just coming out for some track time as last track day for the year :) you wont be going out with the fast guys unless you want too there is groups
What Jess said :D
All noobs are welcome. We run different groups for obvious safety reasons ( based on speed and experience ). As there are some seriously fast cars coming out there could be a difference of 15 seconds per lap.........yes 15 seconds per lap around the south is a huuuuuge difference.
The more the better. And as stated, you have some very experienced people wanting to help you learn and improve :down:
Hi Michele :)
Sorry darl'n, but no. Your mirrors are not big enough to see the fast cars trying to pass you :D
You can bring the GTR though :) :) :)
You're right... I didn't see any fast cars trying to pass me... but don't think it was my mirrors :)
It's okay, I don't wanna bruise any egos anyway LOL
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
