Unfortunatly my baby has to go i love this car and am sure the next owner will as well!!! Bought from AutoStyle where ALL mods were done professionally! Engine mods are as follows: upgraded turbo's bigger injectors bigger fuel pump (in tank) aftermarket adjustable cam gears aftermarket cams complete exhaust turbo's back (nice and quite but still has skyline sound) aftermarket computer (APEXI power fc) car is running around 1.1 - 1.3 bar of boost not exactly sure as when you put your foot down you gotta just hang on no time too look at it. it has some aftermarket rims on it not exactly sure what they are but they look sweet its also lowered (profesionally),it also has a strut brase and also a incabin brase that goes along the back floor to make it a little more stronger and stiffer through the corners like i said this is my baby and don't realy wanna sell but unfortunatly things change!!! Now as i mentioned above i bought the car from autostyle where all mods were done before i purchased the car so i'm not exactly sure what brand names were used on the aftermarket parts , if anyone can tell me how to check injector size and and how to tell what cams and cam gears i have i would be more than happy to do it and let u all know. However i do no that the turbo's are garretts other than that i'm not sure about the rest of it i have the dyno sheet to prove its got the power all you have to do is open the pdf file that i will attach.Also has sony touch screen dvd player.
Also i am in the wollongong area but if u want to see the car i am more than happy to organise a meet half way or so.
Please only legitimate people call as i have no time for DREAMERS and NO TEST PILOTS ANY REASONABLE OFFERS WILL NOT BE REFUSED CAR MUST GO!!!!! U can call or text me on 0421872229 thanks......
$21,000
IMG.pdf
  • Replies 56
$21,000
Also has $1500 alarm system with key pad and u put a sim card in the alarm module and if anyone tries to break in it actually sends a text to your phone...
Will get more photo's up of engiine bay and car in general next couple days...
Car always garaged!!!!!!!
Making multiple threads wont help you. Use one!!!
http://www.skylinesaustralia.com/forums/Ni...62#entry4256562
http://www.skylinesaustralia.com/forums/29...tr-t244516.html
Nice clean looking r32 GTR by the way.
Edited by babyskyline
Thanks mate im sticking to this thread now and thanks for the coment
does anyone have anything reasonable to offer me for my gtr it needs to go NO SWAPS need all the moneyi can get at moment cheers im currently in the process of finding out exactly what kind of garrett turbo's are fitted and also the cams and cam gears should no soon keep u posted but i seriously gotta get rid of her soon cheers!
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drove beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
