Sorry to bring this up again guys, i sure theres a tread about his, but i can't find it unless its about the GTS-t . I know all the turbo version uses Premium Unleaded, but wat about the N/A model? I got the 1993 R33 GTS25 (Non-Turbo!) So wat fuel do u guys use and recommend? Without harming the oxy sensor.
Thanx in advance...
https://www.sau.com.au/forums/topic/24608-unleaded-or-premium-for-na/
Thanks, so i'm assuming that when you guys said premium unleaded you mean ones like BP Ultimate, Shell Optimax, Caltex Vortex etc... Cause BP for instance, aren't there like the BP Ultimate with 98 RON and the Premium Unleaded with i think 95 RON?
Someone clear this up for me please
Thanx again.
ultimate is the stuff man, never heard of premium unleaded from BP, thats just the normal stuff. Ive got a user handbook which says anything over 95 however because they are run on 100 in japan its reccommended to use hihger octane fuel like shell, BP, which are 98 (from memory) caltex (97) and errm the others lol.
nah the handbook i got was an 8 page nuthing really, just had sum general things about the car, nuthin special really. I suggest u go to that website that skyla put on cos they are pretty cheap the workshop manuals, i would get one if i had the money to get it :D everything about the line would be simplified then at least!
Yea i won't spend $250 for the workshop manual but may be $50 just for the owners manual. Is that the one you got nismoman18?
And skyla for this one http://www.jpnz.co.nz/xcart/customer/produ...12&cat=8&page=3 how much is it in aus dollar plus postage and handling, do you know? It would be good if aust has got one here. :D
ight thanx guys...:burnout:
I think the exchange rate at the moment is about $1NZ = 0.87c AU so you would be looking $43.50 AU. Sorry don't have a clue on what postage would cost.
I do have a R33 owners hand book, but it's in Japanese. But it still comes in handy now and then.
Originally posted by nismoman18
ultimate is the stuff man, never heard of premium unleaded from BP, thats just the normal stuff. .
Bp sell their "BP ultimate 98 octane" and a few BP places also sell "premium unleaded" which is 95 octane, instead of ultimate.
My old R33 GTS ran on regular unleaded, which is what was recommended in the Japanese Handbook. The handbook for my GT-V (RB25DE) recommends nothing but "Hi Oku", or premium unleaded.
Incidently, it's commonly believed that the Japanese use 100 octane (RON) fuel over here. So far, I have yet to find a gas station that listed the ratings of the various fuels available, so it's hard to say for sure exactly what octane Japanese pump gas really is!
    • For fuelling the Haltechs have O2WB fuel controllers. Very useful for helping tuning VE and correcting for *small* mistakes. Of course if your injector/cam/trigger/sensor data is just wrong (or for a GTT which is not a GT) then you will get impossible reactions to things. I am sure you know this already but the reason people don't typically put haltechs (or any Aftermarket ECU) on GT's is because there's practically no real gains to be had - So this knowledge won't be commonplace.
    • Can someone tell me if the cracks seen in the rear sway bar bushings in these photo's is unacceptable from a roadworthy point of view?
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
    • For me there is a massive difference in manufacturer or big brand crippled android (Sony, Kenwood etc) vs the sort of thing I've installed here, which is basically just a tablet in DIN form factor with open Android, and the other model of course is mirroring - Android Auto/Carplay. I hate the locked down manufacturer and AA options where they decide what apps I'm allowed to install, including the Launcher but also importantly things like Ecutek (for this car) or Real Dash (Stagea) are not supported. Plus those crippled versions tend to be slower due to both overheads and lower spec hardware. On the other hand, when this breaks I'll likely be in trouble for support....but how is that different to owning an Infiniti anyway
