hi i have a RB25DET and it is stock really. and i was thinking about replacing the turbo with a supercharger like the ones that they use in the holden LS supercharger upgrades that u can get. and it would be nice to know if any body else has put a supercharger on, if it will work, what i will need, and what do i expect to get out of it.
im looking a supercharging it because as i understand it a turbo restricts the exhaust and has two turbines one to power the other which will lower the efficiency of the turbo especially in low rpm were as supercharger will be powered by a belt and is most likely to be more efficient.
if i am way of track then plz tell me
and yes i have seen
http://www.skylinesaustralia.com/forums/Su...er+turbocharger
i am looking a the performance between a turbocharger and a supercharger and also the price difference and what is needed for a upgrade
https://www.sau.com.au/forums/topic/246180-supercharger/
a supercharger is basically a boring version of a turbocharger.
its good for low down power but the top end is no where near as fun.
it takes power from the crank and uses that to suck in air and force it in
a turbo uses exhaust gasses that are already there.
get in a car with a real turbo and see what you think :ermm:
https://www.sau.com.au/forums/topic/246180-supercharger/#findComment-4280062
if you really wanna make it worthwhile it from the ground up with a 3lt bottom end stroker kit, twin turbo and a centrifugal supercharger running into a positive displacement supercharger :ermm:
hope you brought your wallet
https://www.sau.com.au/forums/topic/246180-supercharger/#findComment-4280156
a friend of mine had a supercharged rb25/30 in his vl commy. The amount of time and money it cost was really not worth it. Basically everything needed to be custom made and fabricated, even down to the supercharger. Dont get me wrong, the car went really well, but its a lot cheaper and easier to upgrade the turbo on an rb25
Depends on how much your willing to spend to be different
https://www.sau.com.au/forums/topic/246180-supercharger/#findComment-4280459
Incorrect, a turbocharger is more efficient because it is using something from the engine to make power which is not being used for anything else ie. exhaust gases.
Edited by PM-R33
https://www.sau.com.au/forums/topic/246180-supercharger/#findComment-4280886
Some people were all into doing this on their N/A VL's 3 or 4 years ago, basically isn't worth it for the cost, especially on a small displacement motor. Their usefulness on V8s is even being brought into question with the proliferation of reletively cheap off the shelf turbo kits floating around these days.
https://www.sau.com.au/forums/topic/246180-supercharger/#findComment-4281074
i ran a torana at speedway many yrs ago that run a gm 471 blower with a ait split pulse t4 turbo blowing into the top of the blower .
it was awseome to drive the blower got it of the line like a cat with deep heat on it;s balls and the turbo kept enough air into it down the straights . it was a old 186 block with a 221 falcon crank with a alloy phill irvin head and mechanical endlee methanol injection .
got 3 seasons out of that set up b4 it dropped the crank out of the block every thing was custom made and cost a mint back then but you could not buy anything off the shelf . won many a race beating 350 powered cars i loved it lol
https://www.sau.com.au/forums/topic/246180-supercharger/#findComment-4281971
    • Ahhh, I need the whole head unit. I definitely needed to roll back through and review your setup, ha ha! Neat setup they have going on. I just need a full double din head unit. But I want good and responsive. I might have to review what the likes of pioneer have out these days.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
