I never thought I’d do it but my 180 is for sale. I don’t have the time to enjoy it anymore and would rather have someone else drive it the way I built it for.
THE CAR
1991 180SX sr20det
124,XXX kms
Bought in 2002 fresh off the boat with 64,XXXkms stock as almost a rock, came with blitz bov (gay).
Whether the kms were real or not the car was mint inside out, so I’ve put 60k on the clock myself..only owner in Australia.
No Accidents.
Still has factory overflow bottle and not cracked!!!
Serviced every 5000k’s with Mobil 1, plugs, n oil/fuel filter ($$$)
It’s my daily so reliability is my main concern and its mechanically faultless...
90% of aftermarket parts on the car I bought new and majority of work has been done by myself and with some help from Stan at Motorware, tuning is from Trent at Status Tuning. [email protected]
Car is registered as 2 seater with rear end stripped to be legal with half cage.
Lamborghini red – bit faded (from spray can)
Wheels has been resprayed to metallic white. (bling)
No air-con (racecar)
ENGINE
-Garrett 2871R 52T .64
-HKS step1 264 in/ex cams
-Tomei adj cam gears
-Tomei RAS
-740cc Nismo injectors
-Dtech exhaust manifold
-Screamer pipe (fun!)
-Full 3” exhaust with xforce metal cat (round)
-3” Aspec muffler (possibly only one in aus – from the US)
-Greddy VSPL intercooler kit
-Greddy oil cooler with relocator kit
-Greddy sump (baffles + larger capacity)
-Kazama engine mounts
-Walbro Fuel pump
-Apexi Powerfc
-Z32 AFM
-Pivot Electricity cleaner (clean good, dirty bad)
DRIVETRAIN
-ORC 709D twin plate clutch
-Nismo GT PRO lsd 2 way adj
-S14 gearbox
-Nismo clutch pivot bolt
-Nismo clutch braided line
-brand new S14 clutch master and slave cylinder
-5 stud conversion R33 brakes all round – full skyline setup
-S14 front control arms
-slotted DBA discs all round, DBA 4000 fronts
-Racebrakes pads all round
-Maltech braided lines all round
SUSPENSION
-Tein Super Drift coilovers
-Kazama tension rods
-Kazama tie rods
-Kazama tie rod ends
-Kazama tension rod support bar
-Kazama Hicas remover
-Kazama rear cradle metal spacers
-Kazama metal steering spacer
-Dtech rear upper arms
-Cusco strut brace front + rear
-Rear seatbelt bar
-Whiteline adjustable sway bars front + rear
INTERIOR
-Nardi steering wheel
-Cruise gearknob
-Cruise handbrake button
-Bride Zeta bucket seat (worn)
-Defi BF turbo
-Defi BF oil pressure
-Defi BF oil temp
-Defi BF water temp
-Cusco 5point half cage (welded)
-JVC touchscreen headunit
-Purple tiger skin retrim (oooh yeh)
-Pivot sleepy eye controller
EXTERIOR
-Uras bodykit (copy but fits great)
-Chargespeed front fenders +25
-Bee-R B5 17x9 wheels (discontinued so worth 1 mil already ;)
-Alloy lug nuts
-Bridgestone Potenza RE01 225/45/17 all round
-Genuine typex rear lights + wing
PRICE IS $16,000 NEG.
Contact me on 0401120782.
Please only genuine people looking to buy and no test drives.
No Trades. I’ve set this car up to be a very quick drift/track/street, will not disappoint and has much more potential.
Edited by Lunatic Dancer
https://www.sau.com.au/forums/topic/246208-fs-my-red-180/
    • Pressure when IDLING, is meant to be 51PSi... So that amperage value needs to go up a fair chunk... I'd personally be factoring for more like 12amp at least on those runs, and at that point you need to hope the already there wiring doesn't drop you a volt or two, as that's a lot of fuel pressure flow drop off from 13.5 to 12V! Taking idle pressure of 51psi, means the pump will be drawing a MINIMUM of 9amps all the time based on your reading of the graph (3bar base, then allowing an extra 0.5bar for boost = roughly 51psi)
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
