ive installed a ssq bov a few weeks back and not sure if i should keep it or not... ive noticed since i have installed it, the car has been getting about 100ks less out of the tank and also its shooting out black smoke when i semi floor it...
but i really like the noise of it..
would it be better to keep it and get the car tuned for it or put the stock one back on?
https://www.sau.com.au/forums/topic/246503-bov/
  • Replies 50
Posted Images
tighten it up max, it might be opening to much to early.
https://www.sau.com.au/forums/topic/246503-bov/#findComment-4285067
The jury is 50-50 on fultter/compressor surge turbo damage. Personally i dont think it does much if any damage. Having said that tighten yours max and leave it for a full tank and see how you go. Even if flutter does damage it wont do shit on one tank of fuel.
I hear SSQ leak often so could be faulty bov too
https://www.sau.com.au/forums/topic/246503-bov/#findComment-4285196
its a copy hks, probaly the reason why..I checked it last time, looked like it was installed properly with the plumb blocked off
a copy hks? well there u go.. you get what u pay for.
Try and get the geniune parts when you can! saves alot of hassles.. as it usually will fit and work the first time!
A bit of black smoke when u floor it is normal for a turbo car tho.
https://www.sau.com.au/forums/topic/246503-bov/#findComment-4285421
I had to wind my arc bov up real tight to stop it leaking at idle.. as bizarre as it sounds, it was pushing air out! so now I have mad flutters except when I spool it up then lift off hard. This poor little turbo has taken a beating on the RB20 and now for nearly a year on the RB30.. she'll be right :sick:
https://www.sau.com.au/forums/topic/246503-bov/#findComment-4285530
when i bought it the guy said it had hks written on it so i bought it... arrived 1 week later and the adapter had hks written on it... was really pissed off.. smsed him and he wouldnt reply.. hung up calls aswell
https://www.sau.com.au/forums/topic/246503-bov/#findComment-4285842
i have an hks ssqv as well installed on my car but my fuel economy didnt change much but it does cause my exhaust back fire which it doesnt with my stock bov sometimes when i change gears
from what i know, a bov might make a car run rich due to the fact that it releases the air that was recorded from the afm so the ecu thinks the the amount of air the afm reads is still goin into the manifold and kept it at that exact amount of fuel required for the amount of air recorded by the afm only to realise that the amount of air recorded from the afm has been released by the bov only happens to bov that vents to the atmosphere
on cars with afm the bov will still cause the same incident but on cars with map sensors, it doesnt affect it because it reads manifold pressure(i think) do you have an aftermarket ecu?
https://www.sau.com.au/forums/topic/246503-bov/#findComment-4285861
What a d*ck!
sh!t. Even without tune it shouldnt b that bad, tho mike is right, it will run richer... and tend to stall if u drop the revs very quickly. Tho my blitz bov is running and ive yet to install my safc 2. And i still get roughly 450 for tank.
Hrm, maybe count that as sunk cost and go for a real hks ssq? Try and find one that you can look at first (there is alot of them going around 2nd hand).. or get of reputable sellers... i know Kudos (andrew) on here is very trustworthy as ive bought things off him before.. always answers pm fast, though im not sure if he sells bov's..
https://www.sau.com.au/forums/topic/246503-bov/#findComment-4285864
yes you car is running richer due to you running an atmosphere venting bov. to stop this put stock bov back on or get somesort of ecu(powerfc/safc) and get it tune
As Bubba said, it wont run rich unless the BOV is actuating.
If the BOV is actuating under load. Its not tight enough.
Properly working Atmospheric BOV's will only 'smoke' and run 'rich' when they need to "Blow off" extra air. (And that's to do with changes in Load)
Just tighten it, make it work properly.
That 'Extra' fuel coming through the exhaust would have just gotten burnt by an unloaded engine anyway. Which will not effect your economy. Really, its not extra fuel, because it was going to get injected anyway.
(On a side note, AT A GUESS, because the princeples of induction may counter this - if you plumb back a bov in front of the AFM, you will read that portion of air twice, and then there will be 'extra' fuel injected.)
Your smoke on load is a sign the BOV may not be operating correctly.
I think im just repeating what people have said ?
However there are some myth's being said too.
https://www.sau.com.au/forums/topic/246503-bov/#findComment-4287349
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
