ive installed a ssq bov a few weeks back and not sure if i should keep it or not... ive noticed since i have installed it, the car has been getting about 100ks less out of the tank and also its shooting out black smoke when i semi floor it...
but i really like the noise of it..
would it be better to keep it and get the car tuned for it or put the stock one back on?
https://www.sau.com.au/forums/topic/246503-bov/
  • Replies 50
Posted Images
tighten it up max, it might be opening to much to early.
https://www.sau.com.au/forums/topic/246503-bov/#findComment-4285067
The jury is 50-50 on fultter/compressor surge turbo damage. Personally i dont think it does much if any damage. Having said that tighten yours max and leave it for a full tank and see how you go. Even if flutter does damage it wont do shit on one tank of fuel.
I hear SSQ leak often so could be faulty bov too
https://www.sau.com.au/forums/topic/246503-bov/#findComment-4285196
its a copy hks, probaly the reason why..I checked it last time, looked like it was installed properly with the plumb blocked off
a copy hks? well there u go.. you get what u pay for.
Try and get the geniune parts when you can! saves alot of hassles.. as it usually will fit and work the first time!
A bit of black smoke when u floor it is normal for a turbo car tho.
https://www.sau.com.au/forums/topic/246503-bov/#findComment-4285421
I had to wind my arc bov up real tight to stop it leaking at idle.. as bizarre as it sounds, it was pushing air out! so now I have mad flutters except when I spool it up then lift off hard. This poor little turbo has taken a beating on the RB20 and now for nearly a year on the RB30.. she'll be right :sick:
https://www.sau.com.au/forums/topic/246503-bov/#findComment-4285530
when i bought it the guy said it had hks written on it so i bought it... arrived 1 week later and the adapter had hks written on it... was really pissed off.. smsed him and he wouldnt reply.. hung up calls aswell
https://www.sau.com.au/forums/topic/246503-bov/#findComment-4285842
i have an hks ssqv as well installed on my car but my fuel economy didnt change much but it does cause my exhaust back fire which it doesnt with my stock bov sometimes when i change gears
from what i know, a bov might make a car run rich due to the fact that it releases the air that was recorded from the afm so the ecu thinks the the amount of air the afm reads is still goin into the manifold and kept it at that exact amount of fuel required for the amount of air recorded by the afm only to realise that the amount of air recorded from the afm has been released by the bov only happens to bov that vents to the atmosphere
on cars with afm the bov will still cause the same incident but on cars with map sensors, it doesnt affect it because it reads manifold pressure(i think) do you have an aftermarket ecu?
https://www.sau.com.au/forums/topic/246503-bov/#findComment-4285861
What a d*ck!
sh!t. Even without tune it shouldnt b that bad, tho mike is right, it will run richer... and tend to stall if u drop the revs very quickly. Tho my blitz bov is running and ive yet to install my safc 2. And i still get roughly 450 for tank.
Hrm, maybe count that as sunk cost and go for a real hks ssq? Try and find one that you can look at first (there is alot of them going around 2nd hand).. or get of reputable sellers... i know Kudos (andrew) on here is very trustworthy as ive bought things off him before.. always answers pm fast, though im not sure if he sells bov's..
https://www.sau.com.au/forums/topic/246503-bov/#findComment-4285864
yes you car is running richer due to you running an atmosphere venting bov. to stop this put stock bov back on or get somesort of ecu(powerfc/safc) and get it tune
As Bubba said, it wont run rich unless the BOV is actuating.
If the BOV is actuating under load. Its not tight enough.
Properly working Atmospheric BOV's will only 'smoke' and run 'rich' when they need to "Blow off" extra air. (And that's to do with changes in Load)
Just tighten it, make it work properly.
That 'Extra' fuel coming through the exhaust would have just gotten burnt by an unloaded engine anyway. Which will not effect your economy. Really, its not extra fuel, because it was going to get injected anyway.
(On a side note, AT A GUESS, because the princeples of induction may counter this - if you plumb back a bov in front of the AFM, you will read that portion of air twice, and then there will be 'extra' fuel injected.)
Your smoke on load is a sign the BOV may not be operating correctly.
I think im just repeating what people have said ?
However there are some myth's being said too.
https://www.sau.com.au/forums/topic/246503-bov/#findComment-4287349
    • Get an inspection camera up there.
    • Yeah, but look at the margin in viscosity between the 40 and the 60 at 125°C. It is not very large. It is the difference between 7 and 11 cP. Compare that to the viscosity at only 90°C. The viscosity axis is logarithmic. The numbers at 90 are ~15 and ~35. That is about half for the 40 wt oil and <half for the 60. You give up viscosity EXPONENTIALLY as temperature rises. Literally. That is why I declare thicker oil to be a bandaid, and a brittle one at that. Keep the oil temperature under about 110°C and you should be better off.   Having said all of that, which remains true as a general principle, if you have indeed lost enough oil from the sump that the pump was seeing slightly aerated oil, then all bets are off. That would of course cause oil pressure to collapse. And 35 psi is a collapse given what you were doing to the engine. Especially if the oil was that hot and viscosity had also collapsed. And I would put money on rod or main bearings being the source of the any noise that registered as knock. Hydraulic lifters should be able to cope with the hotter oil and lower pressure enough to prvent too much high frequency noise, although I am willing to admit it could be the source.
    • Thanks for the reply mate. Well I really hope its a hose then not engine out job
    • But.... the reason I want to run a 60 weight is so at 125C it has the same viscosity as a 40 weight at 100C. That's the whole reason. If the viscosity changes that much to drop oil pressure from 73psi to 36psi then that's another reason I should be running an oil that mimics the 40 weight at 100C. I have datalogs from the dyno with the oil pressure hitting 73psi at full throttle/high RPM. At the dyno the oil temp was around 100-105C. The pump has a 70psi internal relief spring. It will never go/can't go above 70psi. The GM recommendation of 6psi per 1000rpm is well under that... The oil sensor for logging in LS's is at the valley plate at the back of  the block/rear of where the heads are near the firewall. It's also where the knock sensors are which are notable for 'false knock'. I'm hoping I just didn't have enough oil up top causing some chatter instead of rods being sad (big hopium/copium I know) LS's definitely heat up the oil more than RB's do, the stock vettes for example will hit 300F(150C) in a lap or two and happily track for years and years. This is the same oil cooler that I had when I was in RB land, being the Setrab 25 row oil cooler HEL thing. I did think about putting a fan in there to pull air out more, though I don't know if that will actually help in huge load situations with lots of speed. I think when I had the auto cooler. The leak is where the block runs to the oil cooler lines, the OEM/Dash oil pressure sender is connected at that junction and is what broke. I'm actually quite curious to see how much oil in total capacity is actually left in the engine. As it currently stands I'm waiting on that bush to adapt the sender to it. The sump is still full (?) of oil and the lines and accusump have been drained, but the filter and block are off. I suspect there's maybe less than 1/2 the total capacity there should be in there. I have noticed in the past that topping up oil has improved oil pressure, as reported by the dash sensor. This is all extremely sketchy hence wanting to get it sorted out lol.
