yah its the number you can get simcards anywhere! any offers? looking for around $80
BAHAHAHAHA!!!
You're shitting me right?
I can walk into Voda, get a similar number, (Yes it will be differen't) but just "as good" and easy to remember, Pay $51, and get $300 worth of credit...
So tell me, why should I pay more for less?
Don't want to crap on your thread by your never going to sell this mate!!!!! It's not even that good of a number!!! You can get similar numbers to this.....
All the best, maybe someone will think OMG what an amazing number!!!! lol
x2 Hahaha could have said it better.
can you transfer a prepaid number to someone else without giving the sim card?
LOL this thread rocks.. Subscribed... Goes along with that mustang forum..
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
