:blink: okay yes i'm a dickhead. was changing the brake fluid an sucked the resivoir dry thanks to a stain on the resivoir2/3 of the way down. now i've got air in the lines somewhere an cant seem to get it out. any help would be great! thanks
https://www.sau.com.au/forums/topic/246984-air-in-r33-gtr-brakes/
You need to bleed your brakes, a very common technique explained on the internet. Basically there is a bleed valve near the break, you pump the brake with the valve open, and you will lose some fluid but also flush any air out.
Start at the rear passenger side, then rear drivers, then front passenger, then drivers side brakes, bleed one at time, very helpful to have someone to help you with this :blink:
Search the forum for more info.
Start at the rear passenger side, then rear drivers, then front passenger, then drivers side brakes, bleed one at time, very helpful to have someone to help you with this :)
yer was doing that when i sucked the air in, than spent 2-3 hours trying to bleed the air out. got some air out to start with but dont seem to be able to get it all out, went back round all the other wheels an couldn't get any air out. yer had someone helping.
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
