Hi All,
HRE Wheels has announced a new line of wheels called the Carbon Series, which will be available from January from The Tuners Group here in Australia.
They are an absolutely mindblowing wheel - simply amazing, and we're incredibly excited about getting our hands on a set asap.
The strength of these new wheels is completely mindblowing. As it says in a quote from HRE Wheels COO Alan Peltier on our site ...
"It turns out that the stiffness of the carbon barrel is actually much higher than the stiffness of the aluminum barrel.
In fact, in fatigue, the (carbon) barrels are load rated MUCH higher than the (forged) aluminum center simply because you have to design the rim around impact."
We've written an article with a bunch of photos of the new wheels, which you can find on our website at ...
http://www.tunersgroup.com/TunerWire_Live/HRE_Carbon.html
I think we just found a new set of wheels for our Time Attack project car :P
- Adam
If for nothing else I would love a set for 'wank' factor :P
They aren't just for looks :)
As it says in our article at ...
http://www.tunersgroup.com/TunerWire_Live/HRE_Carbon.html ...
The main advantages of the carbon fibre wheels are (as reported in this post by HRE COO Alan Peltier) ...
In fact, in fatigue, the (carbon) barrels are load rated MUCH higher than the aluminum center simply because you have to design the rim around impact."
So there are not just a wheel with a cosmetic carbon lip - instead the whole barrel is carbon fibre.
They are truly an incredibly exciting wheel.
- Adam
We received these new studio photos from HRE today of the new HRE Wheels Carbon Series - absolutely amazing wheels ...
Our HRE Carbon Series photo gallery is at ...
http://www.tunersgroup.com/lightboxes/HRE_...lery/index.html
Our article about the new HRE Carbon Series Wheels is at ...
- Adam
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
