Hi i have various gtr and gtst parts for sale
gtst head $500 ,perfect
rb26 dett block $400 perfect
rb26 pistons and rods $250
n1 pump good condition $200
water pump n1 $100 used good condition
standard gtr injectors $200 for 6
1000cc RC engineering injectors $500 brand new never used! bargain
standard r32 gtr turbos $300 the pair good condition slight shaft play.
veilside r32 gtr exhaust good condition $300
r34 gtr stainless dump pipes standard $200 the pair excellent condition
standard r32 gtr intercooler $150 fair condition no leaks
standard r34 gtr cooler $450 brand new
hks rb25det exhaust manifold hpc coated $500
standard r33gtst exhuast $200
standard r33gtst bonnet white $200
standard r33gtst rear wing $150 white
standard r32 gtr suspension $250 front and back
standard r32gtr suspension front only $150
standard r33 gtst 16 inch rims with new rubber $400
standard rb26det exhaust manifolds
rb25det valve covers $100
r32 gtr 2 way diff centre $400
nismo lmgt4 18x 9.5 +30 offset bronze rims and bridgestone re55 semi slicks $3000 firm! excellent condition no gutter rash but semi slicks down to indicator
standard r34 gtr rims with rubber $2000 firm no gutterrash.
rays early gt-c's silver 17 inch with hub adapters and rubber $500 great for drifting!
evo9 brembo calipers $500 pair excellent cond.
buyers to pay all shipping costs from adelaide.
guys please these prices are cheap so be quick and please dont haggle.
will post pics tonight!
i will only answer pm's.
i also have
6 x standard coil packs r33 gtst series 2 $250 all up
6x standard coil pack r34gtr $250 the same as above
6x standard coil r32 gtr coil pack $200
r33 rear taillights pair $400
AGAIN pm me pls
Edited by ax53b70p25
n1 pump good condition $200sold
water pump n1 $100 used good conditionsold
1000cc RC engineering injectors $500 brand new never used! bargain sold
hks rb25det exhaust manifold hpc coated $500 sold
evo9 brembo calipers $500 pair excellent cond.sold
    • I think in the modern era we live in, if I were converting a hydro lifter head to solid, particularly when chasing revs, I'd be seeing what I could do to use shimless buckets. Those of us with Neos usually have this persistent niggling fear of a shim getting spat out and ruining everything. Shim-over is...yucky that way. At least the Tomei kit appears to be conventional, but it would still be nice if they'd decided to go shimless.
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
