Hello :thumbsup:
Just need a little advice on coilpacks for my r32 GTR as i need to replace mine. I know spitfire are 'the best' you could get (maybe) but what about the other brands? I've found the following:
Just-Jap racing brand:
http://justjap.com/store/product.php?produ...=307&page=1
Superspark brand:
http://www.kudosmotorsports.com/catalog/pr...products_id=249
and this other one which im not 100% on:
Performance-wise brand on ebay (the yellow ones)
I'm not looking to get any sort of dramatic improvement and I'm only planning to run stock boost for a while untill i can get better turbos and a PowerFC.
Thankies ^^
https://www.sau.com.au/forums/topic/247471-coilpacks/
I personally have Splitfires and they have been perfect for over 2 years worth of abuse in an RB25 that would be making around 260 - 270 kw at the flywheel.
I hear that the JJR ones are pretty decent value for money though.
https://www.sau.com.au/forums/topic/247471-coilpacks/#findComment-4297310
I looked into this a little and from what people said I couldn't go past the Splitfires. I will let you know shortly what they are like! Cause I have the feeling that at least one of my coilpacks was about to give up on me before my car went in :)
https://www.sau.com.au/forums/topic/247471-coilpacks/#findComment-4297319
When i brought my R32 first little mod i did was Splitfire's notices a little difference in rev's coming on a bit smoother.
Would say they are the best around as i have never heard a bad thing about them yet.
But same goes for the JJR ones, so it all comes down to RED VS BLUE what colour do you like more lol
https://www.sau.com.au/forums/topic/247471-coilpacks/#findComment-4298087
  • 1 month later...
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
