Before I get drilled from all the ps3 junkies. I know the ps3 is better, but I'm impatient and couldn't wait till it came out so I bought the 360.
Also, they're controllers are retarded! Get with the times Sony and make them more ergonomically!
Anyway, point of this thread is if anyone has one and plays on xbox live.
GRID is awaiting.......
https://www.sau.com.au/forums/topic/247687-who-has-a-360/
PS3 controllers are awesome! Keeping in touch with it's root while still updating it with new features and is comfortable. Xbox 360's controller sure its comfy... but its junk... so is the console and I prefer PS3's lineup of exclusives MORE - theres a few good ones on X360 but not enough to warrant me keeping the console.
+1 for PS3!
https://www.sau.com.au/forums/topic/247687-who-has-a-360/#findComment-4300250
What do homo's and Xbox 360 users have in common?
They always have red rings.
Mine had red rings but I got them fixed under warranty. (my xbox that is)
+1 for PS3!
Gay!!!!!! Are you sure the ps3 controllers dont get red rings? :P
https://www.sau.com.au/forums/topic/247687-who-has-a-360/#findComment-4300330
I have both consoles and i am hooked on forza 2 ATM.Cant seem 2 find as many good racing games on PS3.Thrashed GT5 prologue until bored 2 tears but spent tons more hours on forza!Mainly use the PS3 4 watching Bluray DVD.BTW got 360 for free when went on new phone plan :P .Definately prefer 360 controller
https://www.sau.com.au/forums/topic/247687-who-has-a-360/#findComment-4300428
360 all the way
had mine over a year no problems
who gets gta 4 downloads next month? xbox not ps3
Most over rated game of the year - playing GTA4 through the first time was a snorefest I wouldnt touch the DLC even if it was free! I was struggling to finish it because it dragged on too much. I'd eBay it but my girlfriend gave it as a birthday present.
Who got MGS4? PS3 not shitbox 360. check mate! BEST GAME EVER.
https://www.sau.com.au/forums/topic/247687-who-has-a-360/#findComment-4300639
    • Pressure when IDLING, is meant to be 51PSi... So that amperage value needs to go up a fair chunk... I'd personally be factoring for more like 12amp at least on those runs, and at that point you need to hope the already there wiring doesn't drop you a volt or two, as that's a lot of fuel pressure flow drop off from 13.5 to 12V! Taking idle pressure of 51psi, means the pump will be drawing a MINIMUM of 9amps all the time based on your reading of the graph (3bar base, then allowing an extra 0.5bar for boost = roughly 51psi)
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
