Item: 1992 r 32 nissan skyline manual
Website: here
Item Condition: great
Reason for Selling: need money
Price and Payment Conditions: 13000 NO LOW BALL OFFERS
Extra Info: ok here goes.
have put new motor in that had 90000 k's on it. since then ive done 3000k's. when the motor was out it had a new clutch, flywheel, timing belt, water pump, new heater hoses. has a highflowed r33 turbo with to4e internals, turbo has done roughly 3000k's since highflowed. it has new race plugs that were put in thursday arvo, so they've done less then 30k's. always serviced with penrite oils. rebuilt gearbox was put in 5000k's ago. the wheels are genuine veilside. 18x10.5 rear and 10.25 on the front with 225's all round. has a sunroof, sits on tein coilovers, has a full 3 inch exhaust, pioneer headunit with ipod connecter, mp3 etc, top of the range pioneer 6.5" splits, interior is in good condition, dash is not bubbling or split. i have a m spec bar for the front but havent got around to putting it on.
any questions, feel free to ask.
Pictures: yes
Contact Details: luke 0401761994
https://www.sau.com.au/forums/topic/247980-hottttt-32-skyline/
im luvin it looks supa clean but ive only got 7g n a rx7 roller to offer check her out
http://www.boostcruising.com/forums/index....mp;p=1281778814
Edited by DK (DRIFT KING) JENKYNS
personal preferance i guess. yeh mine has some scratches etc and maybe what u call hot is something with flash paint and u can see yourself in the chrome wheels. my idea of hot is something where u cant fit your fingers between the tyres and the guards, where u got enuf dish and enuf camber that when u finish cleaning your wheels theres a pool of water about 10mm deep still sitting in the bottom of each wheel. :banana: most skylines just have the same thing... a set of 18x8's, maybe 18x9.5s at max, its not often u see something like mine where the fronts are just over 10 inch wide and the rears are 10.5's so u must admit even if u dont think its hot,,, its unique.
edit. the guards are standard to, just rolled and lipped a bit
Edited by bsas2
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
