1992 R32 Gts-T
Rb20det 135***km 5spd
Black
Rego Till May 09
selling up the skyline, been a treat to have. Always serviced and looked after.
Ap Eng Power Fc ( tuned by unigroup made 174kw atw)
spitfire coil packs
walbro fuel pump
dna boost controller (13psi)
Fmic
Apexi Pod with heat sheild
ss 3inch dump/front pipe
3inch catco cat
ss 3inch cat back system
Tien Super Street Coilovers
Hicas Lockbar
Rda slotted Rotors
Mu secret Pads
braided brake lines
Uras Front bar (has carbon vynal atm will get sprayed)
Vertex sides / rear
M sports fenders
25mm flare
Recaro Sr3 bucket seat (drivers)
Auto meter boost, oil, water temp gauges (has senders for them also)
pioneer mp3 head unit, splits, fronts and 6x9s
front strut brace
Monkey Brace
strobe kit
also have some spare parts that will go with the car.
looking for about $11,500 or near offer.
NOTE; Wheels do not come with car! Will provide with stockies unless of a reasonable offer ontop of asking price.
Located Around Liverpool.
pm me for more questions or photos.
cheers dave
Edited by SoFly
https://www.sau.com.au/forums/topic/248291-nsw-1992-r32-gtst/
interested in a trade for a sil80?
Car has:
phantom purple respray (dark purple)
full nismo kit icl rear pods
s15 t28 turbo 60 000kms old from s15
s15 brakes with R-Spec pads front and mu secret d1 pads rear
whiteline sway bars (6 months old)
HSD HR coilovers 6 months old
Solid subframe bushes
shimmed diff
rear adjustable camber arms
autometer oil/water temp and oil pressure guages
CD player etc new alpine speakers front and rear
front and rear strut braces (spats)
17inch volk rims front and rear (same as your fronts)
JJR 5 stud conversion
Hybrid front mount intercooler
Greddy oil cooler
turbo timer
boost controller
mines?? chipped ecu
3inch exhaust with flexi fitted on front pipe to stop loosening bolts
Pod filter in covered box for legalities
Cusco catch can
9 puk ceramic clutch (exedy i think)
momo steering wheel
comes with a spare dash (not cracked)
air con full system
plenty of spare random bits
new resonator for middle section of exhaust (bought cat back system and didnt use this)
also has rego till NOV next year.
sure there are things i may have forgotten but yeah that basically it.
car has seen 3 track days.
  • 4 weeks later...
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
