Rare 2000 Nissan Skyline R34 GTT
Black and White
Prics: $24500 ONO
Contant: PM, call/SMS Andy 0434048013 or email: [email protected]
Auction Grade 4
RB25DET Neo 2.5 litre 6 cylinder turbo
5 speed manual transmission
87,200 kms
Gorgeous AVS Model 5s 18" they seem to look good on just about every car on the market
GT-R front bar
Front bar reinforcement
GT-R rear wing
Nismo side skirts
Nismo rear bar
New clear indicators
High quility Carbon fibre bonnet
Top range Kakimoto exhaust
Aftermarket intake (HKS)
Air Box
Turbo Timer
Top range HKS Coilovers (right now lowered)
Blitz huge intercooler
Custom intake piping
6000K HID light
Alarm system
GTR floor mats
CD/MP3/MD player
(And lots of other good stuffs, more details are coming next week when I have time)
Pics speak thousand of words, this car was import by Iron Chef from Japan a few months ago, I'm the first owner in Australia and its a grade 4, which means a very good condition. People all know that Chef always do a good job, and this car has never get any problem. Sadly, the only reason I'm selling the sweet baby is that I'm leaving Australia soon, quite soon: 1 or 2 months, otherwise I
definitely won't let it go in my life! The GTR bodykits look perfect on it and black CF bonnet makes it stand out all the time. Some people may argue that white is the wrong colour for skyline, but look at this one, it already changed ur mind, didn't it? Car goes well on road and did 0-100 in around 5 seconds. What more u want from it? Just finished service at 87000km at GT Autosound, well-known workshop, George know every detail about skyline!
At this stage I'm still quite neg on price cuz I really need a quick sale on that, OR, may consider s15 plus cash then I can easily sell the s15 to my friend. So, don't miss this car, don't make both of us disappointed.
Edited by Obelisk
https://www.sau.com.au/forums/topic/248522-gt-r-face-r34-gtt-for-quick-sale/
Yep, they have been replaced by the previous owner in Jap, and they really did a good job on that.
Hi, did you need to change the bonnet latch assembly and gtt reinforcement front bar?
Regards
Thanx buddy! I must sell it before the end of January cuz I'm going oversea now. Any price around 23K will be considered!!!
gonna be hard finding a buyer at that price, but best of luck i guess, free bump
Thanx for ur guys' offers, but I can only accept swap with something very cheap (I have my way to sell them to my friend) or S15( one of my friend loves it a lot), otherwise still prefer CASH sale.
Cheers!
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
