theminuz Posted December 11, 2008 Share Posted December 11, 2008 hiya everyone, have recently changed all running gear in my R32 to that out of an R33 rb25 engine and gbox. my question being, what engine xmember has everyone used? at the moment im using; rb20 xmember, rb20 engine brackets and engine mounts... i've heard that changing to rb25 xmember, rb25 engine brackets and mounts lowers the engine approx. 20mm or so compared to using the above. i kno that in theory if u make the engine sit 20 mm lower it will affect things like exhaust and fmic piping, but ive look at that and i would have sufficient room to play around with these what are your thoughts... ben. Link to comment https://www.sau.com.au/forums/topic/248577-which-engine-xmember-has-everyone-used/ Share on other sites More sharing options...
jas/slo32 Posted December 11, 2008 Share Posted December 11, 2008 (edited) on all 3 conversions i did i used rb20 xmember mounts and brackets onto rb25det in r32 everything exh etc bolted straight up Edited December 11, 2008 by jas/slo32 Link to comment https://www.sau.com.au/forums/topic/248577-which-engine-xmember-has-everyone-used/#findComment-4312835 Share on other sites More sharing options...
theminuz Posted December 11, 2008 Author Share Posted December 11, 2008 (edited) on all 3 conversions i did i used rb20 xmember mounts and brackets onto rb25det in r32 everything exh etc bolted straight up yer, everything has lined up using the rb20 engine mount setup - my question is "does the rb25 mount setup make the engine sit lower? and if anyone has tried/using it" Edited December 11, 2008 by theminuz Link to comment https://www.sau.com.au/forums/topic/248577-which-engine-xmember-has-everyone-used/#findComment-4312920 Share on other sites More sharing options...
rinmak Posted December 13, 2008 Share Posted December 13, 2008 Using the 33 crossmember with "custom" engine mounts can sit it a bit lower mate. Because the 33 crossmember has a flat mounting surface you can go out and buy generic engine mounts like this which are heaps thinner than standard From what i can tell all the nissan crossmembers are very much the same when doing these conversions. The only way to get it lower is custom mounting hardware. Link to comment https://www.sau.com.au/forums/topic/248577-which-engine-xmember-has-everyone-used/#findComment-4315384 Share on other sites More sharing options...
PRO_32 Posted December 19, 2008 Share Posted December 19, 2008 just a quik Q? With the rb20 engine mounts which way is up or does it not matter. (Bolt up or locating lug up? Link to comment https://www.sau.com.au/forums/topic/248577-which-engine-xmember-has-everyone-used/#findComment-4327598 Share on other sites More sharing options...
bubba Posted December 22, 2008 Share Posted December 22, 2008 There should be a little slot/hole for the locating lug to go into, IIRC it's on the underside. Link to comment https://www.sau.com.au/forums/topic/248577-which-engine-xmember-has-everyone-used/#findComment-4330459 Share on other sites More sharing options...
